Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 01-03-2013, 11:50 PM   #1
Handmedown
Handmedown's Avatar
Welder safety
I'm teaching myself to be a body man. I am going to replace my rockers on 72 c10. Do I have to be concerned about the gas tank, since it is so close to where I will be welding, is it going to blow up?
Handmedown is offline   Reply With Quote
Old 01-04-2013, 12:12 AM   #2
Husker
Husker's Avatar
Re: Welder safety
No it will not blow up. If the valve gets somehow knocked off there is a lot of pressure in there.
I use C25 which is Carbon Dioxide and Argon which are non combustible. They are used to shield the weld.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 01-04-2013, 12:44 AM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Welder safety
I think he meant the gasoline in the tank not the gas in the cylinder.
If the truck is going to be off the road while you do it I would remove the gas tank simply because its easy to do and the hoses are usually rotted or close to it
dwcsr is offline   Reply With Quote
Old 01-04-2013, 01:15 AM   #4
schurg
Re: Welder safety
I'd say if you're willing/able to tackle the sheetmetal work on your truck then you are more then capable of pulling the gas tank out before hand. it's only a hand full of bolts and a couple wires/hoses. not to be a downer, but you might come across more rot to fix under/behind the tank.
schurg is offline   Reply With Quote
Old 01-04-2013, 06:07 AM   #5
Husker
Husker's Avatar
Re: Welder safety
If only I could read.
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 01-04-2013, 11:46 AM   #6
johnnyclack
Location: On the banks of the Clackamas River, Eagle CreeK Oregon
Re: Welder safety
When you pull your fuel tank, be sure to remove it from the area your welding in. It is truly amazing how far a welding spark can travel on the ground. Remember it’s the fumes that create a high percentage of explosions.And why your tank is out do not miss a perfect opportunity to clean the scale/crud out of your tank.
I have a 79’ K-30 w/dual tanks. The first thing on my list is to pull both tanks, clean them out & replace all rubber components.
YouTube has a few blurbs on ways in which to accomplish this task
johnnyclack is offline   Reply With Quote
