Old 01-04-2013, 09:29 AM   #1
erock805
erock805's Avatar
s10 T5 yoke question...
So just about have my step dads up and rolling. Just need a drive shaft. I put in a small block and a s10 5 spd. I am on the hunt for the right one. It looks even the s10 one will fit. I pulled one from a short bed square, automatic, and it seemed that the yoke was different. Looked like a smaller spline and looked like one spline was missing (not shaved off but factory).
I have a 26 spline coming out of the trans...are there a bunch of different options with s10 yokes? I am pretty sure that the s10 came out of a square. Want to drive this thing around the block...
"Do what you want to the girl, but leave me alone!"
erock805 is offline   Reply With Quote
Old 01-04-2013, 11:35 AM   #2
jayoldschool
Moderator
Re: s10 T5 yoke question...
I believe the T5 should use the same yoke as the Powerglide/Th350/Th700R4/Th200-4R. It would be different than the TH400.
jayoldschool is offline   Reply With Quote
Old 01-04-2013, 10:33 PM   #3
CRGRS 66
CRGRS 66's Avatar
couple of threads for you to look at, pretty comprehensive swap information, I personally have a camaro 5 speed with S10 tail shaft sitting in the garage waiting to be installed
http://67-72chevytrucks.com/vboard/s...d.php?t=482069
http://67-72chevytrucks.com/vboard/s...d.php?t=313954
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 01-05-2013, 01:03 AM   #4
erock805
erock805's Avatar
Yup looked through those. Didnt see if they were the same...So I thought I would post up.
They have a couple of the round body s10s with a stick...just no squares.
Old 01-05-2013, 01:04 AM   #5
erock805
erock805's Avatar
that should give me more choices... I will check out some full size trucks. thanks
Old 01-05-2013, 07:00 PM   #6
erock805
erock805's Avatar
okay. so I checked around and went back to the yard. The round body style s10 yoke will work as long as its from a Stick car.
Need to shortin it about 3 "s but it shoud do nicely.
Old 01-05-2013, 09:07 PM   #7
wayno
Thanks for sharing your finding - this is on my list of things to do.
wayno is offline   Reply With Quote
