Old 01-04-2013, 10:20 AM   #1
TheOtherScott
Which choke thermostat?
Hi guys! First post! I've got a lot of great information from you guys on this site so I'm hoping you can help with this.
I got my '69 Chevy SWB about 6 weeks ago and the PO said it was a 327 (but I haven't yet found the casting numbers to be sure). It came with a Edelbrock that wasn't quite right so I replaced it with a rebuilt Quadrajet (7028282) from LMC. Question is what choke thermostat do I look for?
TruckAndCarShop.com says they have one for a '69 327 but does this photo look to you guys like that's what I have? Any help would be great!
TheOtherScott is offline   Reply With Quote
Old 01-04-2013, 11:01 AM   #2
JimKshortstep4x4
Re: Which choke thermostat?
Welcome to the 67-72 Chevy Truck board from West Michigan!
Your manifold is from a newer Small block so the 67-72 truck chokes won't work. Here is a picture of a choke that is similar to the truck chokes. Also, note the difference between the manifold in my picture and the manifold in your picture.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 01-04-2013, 11:05 AM   #3
TheOtherScott
Jim
Thanks for the info! Glad I asked before I ordered the one for the '69. Do you suppose a visit to a Chevy dealership would so me any good?
Old 01-04-2013, 11:47 AM   #4
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
You will probably need to switch to the older style manifold since you already have the older style carb
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 01-04-2013, 11:49 AM   #5
TheOtherScott
You're probably right but I really hope not. I was hoping to find a thermostat and just adjust the connecting rod accordingly to get the choke to operate.
Old 01-04-2013, 11:51 AM   #6
TheOtherScott
Anybody have a guess as to what year that manifold would be from?
Old 01-04-2013, 11:58 AM   #7
68gmsee
Active Member
68gmsee's Avatar
I have an intake like yours that came out of a '75 350. I'm using a carb with an automatic choke I already had.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 01-04-2013, 12:01 PM   #8
TheOtherScott
THANKS! That looks exactly like mine! I've searched quite a few times and could never find a photo that would show one like mine or if it did, it didn't say what it was from.
Old 01-04-2013, 12:15 PM   #9
68gmsee
Active Member
68gmsee's Avatar
If you post the numbers on the scraped off area on picture above in front of passenger side valve cover, we may be able to determine what you have.
06 Trailblazer
Old 01-04-2013, 12:19 PM   #10
TheOtherScott
I'm at work right now but I had it written down. I couldn't find anything about these numbers but I think it says K02040B. I didn't take the alternator off to see for sure. Any help would be great, thanks!
Old 01-04-2013, 12:23 PM   #11
71K20chevy
71K20chevy's Avatar
Can't see it the greatest, but we made a bracket that goes under one of the manifold bolts for mine:
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 01-04-2013, 12:27 PM   #12
TheOtherScott
I may try that with a thermostat that I have. I was concerned that it would not heat up fast enough. I guess having the choke come off too slow is only going to use a bit more fuel. Thanks for the photo!!
Old 01-04-2013, 12:29 PM   #13
71K20chevy
71K20chevy's Avatar
No problems warming mine up in the morning, works like a charm
71 K20
64 GMC mud truck
Old 01-04-2013, 12:32 PM   #14
TheOtherScott
Thanks again for you help!
Old 01-04-2013, 12:43 PM   #15
Ol Blue K20
My memory is starting to warm up and that pic of the aluminum manifold just kick started it. I believe edlbrock makes a block that bolts over that spot becauase new manifolds are made to accept the newer style heat tubes and they make an adaptor to go to old style
Dale
Old 01-04-2013, 12:46 PM   #16
TheOtherScott
I'll see what I can find about that.
Old 01-04-2013, 12:52 PM   #17
Ol Blue K20
Summit might be able to help you out
Dale
Old 01-04-2013, 12:53 PM   #18
TheOtherScott
I'll check on their website. Thanks!
Old 01-04-2013, 01:52 PM   #19
RenoKeene
Florida Edition
RenoKeene's Avatar
If you post up the manifold casting number we can tell you what it is, also the block casting number is on the top driver's side where the tranny bolts to the block and the build date is on the pass. side. Best way to see it is to hold your camera back at the firewall pointed down and snap some pics.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 01-04-2013, 01:55 PM   #20
TheOtherScott
I'll have to check tonight or tomorrow and see if I can find those numbers. It would be nice to know for sure what I'm dealing with.
Old 01-04-2013, 04:16 PM   #21
RenoKeene
Florida Edition
RenoKeene's Avatar
Also you could pull a valve cover and get the head casting number, a lot of things get swapped around in 40 years.
Old 01-04-2013, 04:21 PM   #22
TheOtherScott
I'll probably get those numbers, too.
Sorry to be dim here but are the heads not as interchangeable?
Old 01-04-2013, 06:16 PM   #23
68gmsee
Active Member
68gmsee's Avatar
Interchangeable yes, but there's differences in them like intake/exhaust size and how they were designed for better fuel flow and compression.
06 Trailblazer
Old 01-04-2013, 06:21 PM   #24
TheOtherScott
I see. I don't think much would surprise me with this truck anymore whatever it has on it...
Old 01-07-2013, 11:30 AM   #25
TheOtherScott
Well the head casting numbers are 3927185.
What I can find says those heads are for a '69 327 and '67-'73 307 & 350.
The PO told me that his PO told him they put a 327 from a Monte Carlo in this truck. I think Monte Carlos came out in '70 and never came with a 327 so all this would lead me to believe this engine is a 307 or 350 in the range '70-'73.
Can't see the block casting numbers as the engine is too close to the firewall. Anyway I rigged up a choke thermostat from a early '70's 350 similar to what 71K20CHEVY showed in his photo and it seems to be working pretty well.
Thanks to everybody for their photos and suggestions!
