Old 01-04-2013, 04:41 PM   #1
jsbgump
Gone Fishing
jsbgump's Avatar
fuel line and fitting help
I'm fixing to order my fuel system parts. i will be useing a ploy blazer tank with the whalbro 255 pump and the wix 33737 vette reg/filter. I have a returnless fuel rail engine. I'm looking at 20ft of braded -6 line. I just want to make sure how many fitting and the correct numbers to make my order and get everything I need the first time if possible. thanks
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 01-04-2013, 04:43 PM   #2
Jon01
Jon01's Avatar
Re: fuel line and fitting help
I just draw the whole system out on a piece of paper and put together a spreadsheet of part #'s, costs, etc... Much easier that way.
Jon01 is offline   Reply With Quote
Old 01-05-2013, 12:59 AM   #3
jsbgump
Gone Fishing
jsbgump's Avatar
fuel rail fitting Russel 640850
8 hose ends
670470 x2 for the pump
640860 return of the pressreg/filter
2 fittings for the tank
and the other two for the press reg/filter
I think I'm getting closer
Build Thread
Old 01-05-2013, 11:23 AM   #4
jsbgump
Gone Fishing
jsbgump's Avatar
Ok so here's my parts list
summit 20 ft line 230620
fuel rail and inlet of reg/filter 640850 qty 2
return from reg/filter 640860
outlet from reg/filter 640940
fuel pump 670470 qty 2
fuel tank 220648 qty 2
hose end fittings 220690 qty 8
walbro gsl392 pump
wix 33737 reg/filter
I think this should cover it
and -6 an wrenchs 900106
Build Thread
Old 01-05-2013, 11:47 PM   #5
Shooters_7
Look at post #36 in my build. I put in a Boyd fuel tank with the electric fuel pump. I think your fittings and filter/regulator are going to be the same. Good luck and its easy to build these lines!
Conner
1965 Build: http://67-72chevytrucks.com/vboard/s...d.php?t=535078
Shooters_7 is offline   Reply With Quote
Old 01-06-2013, 12:44 AM   #6
85burb
85burb's Avatar
If you do the quick connect to factory fuel rail make sure that it is the kind with the screw on end not the plastic kind. Lots of guy have had them blow off or leak real bad. 644130 This is the part number on summit for the 3/8 size. Pretty sure they are about the same price.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 01-07-2013, 08:46 PM   #7
Shooters_7
like yhis one....
Conner
Old 01-07-2013, 09:13 PM   #8
jsbgump
Gone Fishing
jsbgump's Avatar
Yup I ordered them. the 5/16 return line one is backordered right now
Build Thread
Old 01-07-2013, 11:16 PM   #9
71chevystep4x4
71chevystep4x4's Avatar
I wish I would have known that about the plastic clip kind sooner, I was planning on putting mine on this week.
71chevystep4x4 is offline   Reply With Quote
Old 01-08-2013, 01:01 AM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
In case there is any confusion;
The plastic quick connect fittings that auto parts stores sell, plastic OUTSIDE with a poly or metal center clip, work just fine. They are the kind you see in fuel line repair kits.
The ALUMINUM quick connect AN fittings with the plastic center clip FAIL, and the company denies it.
The ALUMINUM quick connect AN fittings with the screw on METAL retaining section are the revised safe design.
To clarify if there were an misconceptions.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
