01-04-2013, 05:04 PM | #1 |
Steering Wheel Swap with Turn Signal Cancel Cam (HELP!)
I bought a late model S-10 ('91) steering wheel for my '69 truck. I can't get the '91 steering wheel on all the way. The turn signal cancel cam protrudes out too much. Did anyone making this swap have to modify their cancel cam (white round thing that holds bearings down)? Or were you able to use the 90's style cam? Not sure if the later model will fit on the bearing side. It looks a little different.
01-04-2013, 05:14 PM | #2 |
Re: Steering Wheel Swap with Turn Signal Cancel Cam (HELP!)
http://67-72chevytrucks.com/vboard/s...ad.php?t=79039
Check out that link. It's only two posts, and from what I read, looks like it may help you solve your dilemma.
-Nathan- 1972 GMC K2500 Suburban "The Project" 2013 GMC Sierra 1500 SLT Z71 "The Daily Driver" 2005 Ford F150 Lariat SCrew 2WD "The Daily Driver" SOLD 1995 GMC Sierra C1500 SLE "The Daily Driver"SOLD 2003 Ford Ranger Edge 2DSC 2WD Flareside "The Daily Driver/Project"SOLD |
01-04-2013, 05:37 PM | #3 |
I read that post. And feel more confused than when I started. LOL I get the part where he is saying to use the spring and contact point/wire from the '92 steering wheel in the cancelling cam from the 1969.
I don't follow the point where he said to remove the metal rod and spring from the van steering cam???? He never said what to do with those parts. And still the same as when I began.........My 1992 steering wheel will not slide completely on the steering shaft threads with the stock turn signal cancelling cam. The cam is spaced to wide. There is no room left on the shaft for the nut to screw on. Anyone else tried this modification? |
01-04-2013, 08:47 PM | #4 |
When i swapped on my billet wheel it would not fit and i spent like an hour messing with it. Finally went to put the old wheel back on and SAME problem! Wouldnt push on enough to put the nut on. What the hell? Anyways turned out that the steering shaft slid down a bit into the column and thats why there wasnt enough sticking out to be able to screw the nut on. I pulled the shaft back up and then everything fit no problem.
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
01-05-2013, 01:13 AM | #5 |
OK....I got this. Thanks to all of you for your knowledge and help. And help with me finding the right posts. My boss says I spend all day looking for the answer within the threads and finally break down and ask. I guess he'd rather me do work while at work.
On to fixing something else. Plenty of things to choose from on my old ride. |
