Old 01-04-2013, 06:02 PM   #1
Juspassinthru
Exclamation Pic request: Rustoleum Saddle brown primer
Not looking to start a debate on the whole paint vs primer thing just post pics if you have em and or your experiences with it,
Thanks fellas
Juspassinthru is offline   Reply With Quote
Old 01-04-2013, 10:17 PM   #2
rustyrodknocker
Re: Pic request: Rustoleum Saddle brown primer
If your talking about the red primer. I like it for a lot of things. It is often used for structural steel and left unpainted forever. I like to use it as a cheap high build. I drag home a lot of $500 Junkers and make the run. But don't like to put a bunch of money in materials on those. I just did a top on a former vinyl top car it was crusty from the glue. I put down several coats of the red with a light sanding between and then an epoxy primer/ sealer on top I use it on frames also with the black enamel.
rustyrodknocker is offline   Reply With Quote
Old 01-04-2013, 10:27 PM   #3
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
66 C20 Service Truck:
Old 01-05-2013, 03:29 PM   #4
newbe351
Originally Posted by LostMy65 View Post
Nice!
newbe351 is offline   Reply With Quote
Old 01-05-2013, 03:45 PM   #5
ol_skool_chevy
ol_skool_chevy's Avatar
Its fine for like NEWBE351 said "structural steel and left unpainted forever"
. From my experience, its not a good sanding primer. it tends to clog up the paper. I use grey. Much nicer sanding. But if you have no plans to sand it. Im sure its a fine primer.
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
