![]() Join Date: Feb 2010
pro touring go fast parts! f/f rear. 8 to 1 steering box, truck arms
speedway engineering full float ford 9" rear. 1.5 degrees of negative camber built in. 13" 6 piston wilwoods. winters aluminum 3rd member. detroit locker and richmond 3.75 gears. new nascar truck arms. steering box is a lee mfg. this thing is a 8to1 ratio. QUICK is an understatement. just over 1 turn lock to lock. any questions let me know. thanks in advance, glen want to sell as a package but may split up.
$2500 rear/brakes/3rd member. $350 for the arms. $650 for the box. +ride
my build threads, 68 pro touring, auto cross c10 (mid life crisis) http://67-72chevytrucks.com/vboard/s...d.php?t=464109 website http://www.sauersgarage.com/ |
![]() Join Date: Oct 2012
Re: pro touring go fast parts! f/f rear. 8 to 1 steering box, truck arms
I'll take the gear box
Posted via Mobile Device |
steering box is sold. thanks Mikey
Interested in selling just the gear or are you wanting to keep it with the housing?
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 1972 Chevy SWB Highlander OLIVE Build thread coming |
$750 + shipping? i have just over $1000 in it
Okay, I figured I'd ask. There's a local guy that'll build a gear to spec and he is asking 450 complete so I figured I'd see what's on the market. I guess 450 is a good deal
do you have better photos of the Trailing arms???
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
headed to a wedding. will get some later or in the am.
sorry it took so long. these are race car stuff. they bolt in. i weld man adjustable panhard bar mount on the back of the drivers side arm. and run coilovers. or wled a 4" ring and a threaded stud to then and screw on a bag or bolt down a coil.
Whats the length of the hub? Tip of the bullet style cap to the face of the axle flange.
flange to flange is 63.5", flange to point of bullet is 4.75". bullet dust cover is 2 piece, flat plate and then the cone. with the cone removed it is only 1.375". give me a call if you want. i want to move some stuff. i have a home for the center section if that helps. glen 802-375-5751
open for offers on the housing and axles. have crate and ready to ship.
#13 |
Brakes still available?
#14 |
#15 |
Glen like we talked I will take all the stuff
Thanks Posted via Mobile Device |
#16 |
done deal!
