![]() Join Date: May 2010
Flipping shackles on an AD?
I saw were nebdrummer flipped the rear shackle mounts on his 3/4 ton AD. Has anyone tried this on a 1/2 ton?
Re: Flipping shackles on an AD?
It doesn't work on a 3100 because in theory they are already flipped. Actually there is no place for them to go the way they are installed from the factory.
#3 | |
1/2 ton springs are directly below the frame, so the flip will not work. |
^ this. Also, why would you need to? The half tons also have it easy because you can just throw some blocks under the axle and drop the crap out of it.
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit! http://67-72chevytrucks.com/vboard/s...d.php?t=380212 |
I was trying to get away from running blocks. With 3" blocks and 15" tires there is a scrub line issue.
#6 | |
Have to looked at lowering leaf springs? A bit more on the expensive side unfortunately. I put 3" blocks under my leafs and as great as it is, it isn't low enough for me. The leafs are something I was considering, but we will see.
"Dixie" - 1988 Chevrolet V30 CC DRW "3+3" | 7.4L 454 (L19) | TH400 | 4" lift | 35"s "Lucille" - 1949 Chevrolet 3100 (on hold) |
I would hate to buy lowering springs and find there was not a big difference since my springs had sagged to much. I have thinking about getting some spring from a late model truck and making my own mounts.
