Old 01-04-2013, 06:44 PM   #1
Gunster89
Gunster89's Avatar
anyone swapd 292 - small block
alright so I had life kick me in the butt and know my 66 gmc big block swap is on hold for a year or so curently I have a 292 in my truck I have a small block 305 im going to put in the truck temporarily because I miss driving it ive been told the transmition will bolt right up to the small block and I have to move the engine mount up a bit will I have to do anything else to make this swap work? will I have to get the drive shaft extended / shortened please anyone who has done this swap help the 292 is dead so yea I havent driven my truck in over 6 months and its killing me I want to drive it if you know what I mean
Gunster89 is offline   Reply With Quote
Old 01-05-2013, 12:55 AM   #2
Captainfab
60-66 Nut
Re: anyone swapd 292 - small block
Yes a small block will bolt right up to your bellhousing. The 292 flywheel should bolt up to the 305 as well. As for the motor mounts, you will need a passenger side motor mount bracket to bolt into the rear location to match the drivers side. The 292 uses offset motor mounts. If you don't move the transmission, you do not have to do anything with the driveshaft.
Old 01-05-2013, 10:38 AM   #3
Gunster89
Gunster89's Avatar
thank you captain
Old 01-05-2013, 10:43 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Beware of the part about the flywheel bolting up. Every 292 I've ever had used 1/2 flywheel bolts instead of 7/16. If that's the case, the holes will be too large when you bolt it to the small block and it will wallow around.
Old 01-05-2013, 11:01 AM   #5
Gunster89
Gunster89's Avatar
tyvm great to know
Old 01-05-2013, 12:23 PM   #6
WTexChevy
WTexChevy's Avatar
You will also need a clutch bell crank pivot ball that screws into the side of the block, NAPA can get this for you. If you are using an HEI ignition, you will need to run 12v to the dist. aaaaand make sure your 305 crank has a pilot bushing installed, if not (probably not) you'll need one of those.
Thats pretty much it
WTexChevy is offline   Reply With Quote
Old 01-06-2013, 01:21 AM   #7
Captainfab
60-66 Nut
Thanks for catching that. It's been a long time since I've had a 292 out.
Old 01-06-2013, 07:02 AM   #8
Gunster89
Gunster89's Avatar
oh well now I had a sbc 400 drop in my hands is there anything different from above needed? and yes its got hei and what does this clutch bell crank pivot ball do exactly is it basically the support for my clutch pedal?
Old 01-06-2013, 07:15 AM   #9
rtk434
The 400 will bolt in with the same changes mentioned above. 400 sbc's are externally balanced so you'll need an appropriate externally balanced flywheel.
Jeff Moyer
65 LWB fleetside 292 4 speed
85 Camaro 436" SBC with a little nitrous 8.12 @ 169 in street trim
rtk434 is offline   Reply With Quote
Old 01-06-2013, 07:18 AM   #10
Gunster89
Gunster89's Avatar
and any idea on what somthin like thats gonna run me?
Old 01-06-2013, 07:28 AM   #11
Tx Firefighter
A new 292 flywheel from Rock Auto which the manufacturer does note has 1/2" bolt holes
ATP part # Z295 which costs 75.79 plus 12.66 for shipping to Prescott Arizona.
A new 400 small block flywheel from Rock Auto which the manufacturer notes is for external balance engines
ATP part # Z294 which costs 72.79 plus 12.93 for shipping to Prescott Arizona
I cataloged the 292 flywheel for a 71 model C20 truck with a 292 and the 400 small block flywheel for a 74 model K20 truck with a 400.
Old 01-06-2013, 07:40 AM   #12
Gunster89
Gunster89's Avatar
Smile Re: anyone swapd 292 - small block
tyvm greatly appreciated will this radiator be a good choice for the 400 my radiator needs to be changed asap
http://www.ebay.com/itm/3ROW-ALUMINU...16bdc6&vxp=mtr
Old 01-06-2013, 01:01 PM   #13
WTexChevy
WTexChevy's Avatar
It supports the bellcrank (Z Bar) that mounts to the frame. The 6cyl will have a bracket with a welded ball on it and the V8 uses a stud mounted ball that threads into the block. (I assume all V8 blocks have the threaded boss for it but I would check before intalling engine)
Here's what you need:
http://www.ecklerschevelle.com/cheve...1964-1972.html
Old 01-06-2013, 02:44 PM   #14
414banger
414banger's Avatar
just did the same swap recently it is pretty straight forward napa has the ball stud that u need to use your clutch linkage also not sure on the clutch and flywheel itself i replaced everything new when i did the swap but u do need the right side motor mount
414banger is offline   Reply With Quote
