Old 01-04-2013, 07:28 PM   #1
Juspassinthru
Question Does changing tire sizes affect speedo?
Im running a set of 215 70 15's . Not sure wha thesE trucks came with originally. Thx
Juspassinthru is offline   Reply With Quote
Old 01-04-2013, 07:37 PM   #2
PAPA KENT
PAPA KENT's Avatar
Re: Does changing tire sizes affect speedo?
i don't have a chart anymore but i believe a p215/75r15 is close to the originals.i run a 245/75r15 and mine is 5 mph off.some one here will have a chart for rotations per mile for each size.
PAPA KENT is offline   Reply With Quote
Old 01-04-2013, 07:51 PM   #3
Tshort1
Tshort1's Avatar
Yes! you can Google tire size calculator.
Tshort1 is offline   Reply With Quote
Old 01-04-2013, 08:33 PM   #4
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
This is a calc I use.
http://www.miata.net/garage/tirecalc.html
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 01-04-2013, 08:53 PM   #5
jocko
jocko's Avatar
agree with above - answer is yes, but the easiest way to figure it out is use/borrow a gps to see how far you're off from reality. keep in mind that in many of these oldies, the rear gears have been changed also, and that will much more significantly throw off the speedo. If you crosscheck displayed speed on speedo with a gps, you'll at least have a mental correction factor that covers all things that contribute to your speedo being off. Or, you'll discover that you're pretty darn close. agree with others, you're pretty close to factory tire outside diameter - that is what matters when it comes to tire changes.
