01-04-2013, 07:36 PM | #1 |
sm465 clutch
i have a 1985 k-10 350 sm465 205 im looking for a hydrallic setup for clutch
is there any reasonable priced kits or is there a setup from a newer truck or something that will work any help will be great thanks |
01-04-2013, 08:35 PM | #2 |
Re: sm465 clutch
None of my business, but my 83 SM465 BB is easy to depress, or is there another reason for it? My idea is to keep the truck as simple as possible - just one more thing to repair.
01-04-2013, 08:54 PM | #3 |
Re: sm465 clutch
its not that bad to depress anymore anyway-had to get used to a clutch again- when i go off road an body twists a little its a pain to switch gears
01-04-2013, 09:42 PM | #4 |
No No
I know they like to sell the born and beck 3 finger clutches when you say 4wd I was so glad when I had to to put a clutch in my moms friends jimmy and went diapharm. actually 88 up you can steal the hydraulic stuff from if you wanted to
Posted from 67-72chevytrucks.com App for Android
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
01-04-2013, 09:43 PM | #5 |
Re: sm465 clutch
I thought '85s had hydro clutches from the factory...
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
01-04-2013, 10:01 PM | #6 |
Re: sm465 clutch
the truck originally came with a 305 at 208
i have swapped it all out for whats in it now do i need to swap the bell housing for hyd or is the hole for the fork enough room |
01-04-2013, 10:16 PM | #7 |
Re: sm465 clutch
Slave cylinder mounts to bellhousing for hydro setups. You would need the newer bellhousing, 85-91 Squares according to GM. Also 85-91 G-Vans, and 85-90 P-Series.
EDIT: GM Part number is 15530202, search it on ebay. You'll see the difference between it and yours immediately.
01-05-2013, 01:42 PM | #8 |
Re: sm465 clutch
thanks for info
yeah i see the difference an wow what a price lol 83GMCK2500 how is your truck cumn along thats a nice looking truck hopefully one day mine will look a little straighter an less holes |
01-07-2013, 03:02 AM | #9 | |
Re: sm465 clutch
Oh, very very recently scored a pair of the early square 16" GMC center caps and a '73/'74 GMC Tailgate with negligible rust.
