Old 01-04-2013, 10:05 PM   #1
ivorton74
ivorton74's Avatar
lmc truck lsx mount adapters and headers
looks like lmc has lsx swap adapters and headers now...
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=49
ivorton74 is offline   Reply With Quote
Old 01-07-2013, 04:03 PM   #2
OldCreek
OldCreek's Avatar
Re: lmc truck lsx mount adapters and headers
I saw that.... I guess that'll make it easy for some guys. But, with a little research someone could probably do it a little cheaper.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 01-07-2013, 05:00 PM   #3
Jon01
Jon01's Avatar
You can get those plates for $40 on ebay with the hardware.
I'm not sure on the headers but I'm sure they are just repackaging someone else's product.
Jon01 is offline   Reply With Quote
Old 01-08-2013, 01:19 AM   #4
crazy longhorn
Fabricate till you "puke"
Those are headman headers....I picked up Hooker streetrod shorties , for $225 (carshop inc,Moline il). The plates, also from the moline shop....the long set , for setback(have to check, but I think 50 bucks). The eng lift plate also came from the same spot.....I like to work with my local speed shop, They always have my back crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-10-2013, 02:02 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Cool....but I'm pretty sure those block huggers don't fit a ton of these applications.....and they DONT SELL THE FREAKING FLANGES SHOWN SEPERATE....
I already have some...but someone needs to mass produce the flanges in mild steel for a good price.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-10-2013, 02:25 PM   #6
Jon01
Jon01's Avatar
You want header flanges for an LS motor?
There's a local guy here that makes them and sells them on Ebay for dirt cheap IMO.
Old 01-10-2013, 07:20 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Not the actual header side flanges (found those laser cut on ebay as well ), but the b-pipe flanges/cat pipe flanges. All I could find was the ls1 style, which arent' the same, and mostly in stainless (which I suck at welding). I ended up laser cutting some, but I'm surprised they werent more available.
Old 01-10-2013, 07:42 PM   #8
Jon01
Jon01's Avatar
B-pipe?
Old 01-10-2013, 10:11 PM   #9
crazy longhorn
The gen I, dont fit the bock huggers, as they dump midway on the block....on the gen 3, they dump under the 3rd port Set the engine back a tad, and watch what works crazyl
Old 01-11-2013, 01:50 AM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Originally Posted by Jon01 View Post
B-pipe?
b-pipe is another name for a midpipe or downpipe or cat-pipe (occasionally test pipe if there was a cat delete). IMO its really only a downpipe on a turbo car, and some cars have a seperate cat-pipe, but with modern cars having multiple cats, the b-pipe is sometimes used to refer to the pipe in between the manifold and the cats, OR the flanged pipe between the manifold and something like a front merge pipe or y pipe.
Reading that I'm pretty sure i just made it more confusing.
Its After the engine, and Before the Cats
Hey longhorn, I didn't know that. I had to move my engine forward a tad to clear the firewall and make room for the 4l80e, and every set of huggers I could find dumped RIGHT into the perches.
Old 01-18-2013, 12:31 PM   #11
solidaxel
solidaxel's Avatar
I'm watching for updates on flanges !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
