Old 01-04-2013, 10:18 PM   #1
orange72sub
2004 LQ4 6.0 mating to a 700r4?
Hey guys trying to figure out the best way to go about updating the drivetrain in my 1972 K20 suburban. I am currently in the process of repainting the truck. I would like to address the tired smokey engine next. I want to go with the LQ4 6.0 out of a 2004 2500 truck. The question is what trans should and could I use with this engine? I have a good working 700r4 with an np205 transfercase in the truck now. Will the 700 r4 work? How do I hook up the kick down cable and vacuum advance up? Any thoughts and advice would be much appreciated THanks
orange72sub is offline   Reply With Quote
Old 01-05-2013, 11:05 AM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 2004 LQ4 6.0 mating to a 700r4?
I doubt the 700 will live long behind that 6.0 and in a 4x4. I would go with a 4l80e for auto or an NV4500 for a manual. They can handle the power potential of that 6.0.
The 700 can be built to handle the power however it is rather expensive and I bet it wasnt built more than a stock trans to begin with.
Good luck fellow Lsx brother!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-06-2013, 01:41 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
That 700 will be a sacrificial lamb. First off I hate adjusting TV cables, and I don't trust the aftermarket TV setups made for putting a 700r4 behind these motors.
If you plan on keeping the engine at stockish or mild power levels, then a 4l60e is the cheapest option (basically a 700r4 with an electronic overdrive and some other updates). While I personally think they are a bit weak, they aren't bad if maintained, and can be built to handle reasonable power levels.
Personally, my choice behind anything bigger than a 5.3, is the 4l80e. Still plenty of them around, they cost a bit more up front but a clean junkyard or craigslist running trans will live behind a stock or mild lq4. With a stock rebuild, they can live for a long time and take a lot of abuse if maintained. Built 4l80es are the closest thing to bomb proof you can find for an overdrive trans.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-06-2013, 12:02 PM   #4
orange72sub
I am fine with stepping up to a 4L80E the question then would be what transfer case do I use? Can the np205 bolt up to the 4L80E? Or do I need to use same transfer case that came on the 4L80E? Will the newer transfer case line up with my axles?
Old 01-07-2013, 01:05 AM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
....and thats where I stop answering....I only put power to the useful wheels
seriously though, 4x4 stuff is out of my element, someone will have to take this one over.
Old 01-07-2013, 03:49 PM   #6
OldCreek
OldCreek's Avatar
In order to go to the 4L80e you will need to swap transfer cases to a 32 spline input NP205 and find the correct adapter to mate the two.
For ease and cost effectiveness, a 4L60e (4wd) will adapt to your current np205 with an adapter and a little work. Said adapter can be had from AA.
Keeping the 700r4 will require information that I can't provide...
Note, the 4l60e came stock behind many 6.0L... e.g. 2005 Escalade 6.0l LQ9
(TH350, 700r4, 4L60e all have 27 spline outputs)
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 01-07-2013, 07:28 PM   #7
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
true....but with a 6.0 from like 2001up or so they are actually the 4L60e-HD or 4L65e...w/5 pinion planetary vs 4... and a few other upgrades.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 01-08-2013, 08:12 AM   #8
orange72sub
would a better plan involve using the transfer case from the late model donor and just find a different offset front axle? Just throwing it out there. I am not even sure what the offset difference is between the two transfer cases or what front axle would line up.
Old 01-08-2013, 11:05 AM   #9
68GMCCustom
I would look for an adapter for a modern trans using your old t-case.
Kurt -
Old 01-09-2013, 02:09 PM   #10
OldCreek
OldCreek's Avatar
Great information!
Old 01-09-2013, 11:56 PM   #11
orange72sub
Thanks guys for the feed back I'll let you know what I find and how it all works out.
