01-04-2013, 10:41 PM | #1 |
Door/top window seal
So before I start parking my jimmy outside, I need to replace the door/top window seal. Ordered some are they are glue on. Yet my double top uses the t style push in's.
Are we to make our own holes? Or does someone make a set with the holes already in them? I did some quick searching and found another post about this, but no answer was provided.
2008 Sierra k3500 LMM 1994 s10 blazer 4x4 1991 Camaro Vert Rusted in Half RIP 1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364 1967 C10 L6/3tree(dads truck) |
01-05-2013, 11:02 AM | #2 |
Re: Door/top window seal
I recently put new rubbers on mine. My first experiance at this. There was none. Just glue residue. I didn't use glue. Just press in. They seem fine. Got them from LMC. Made in Thiland. Quality and fit is poor. There must be a better place to get them.
4oldcars Driving: 1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado The ones I let go: 1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed |
01-05-2013, 11:40 AM | #3 |
I replaced mine last year with the t-clip style. It's amazing how much it leaks, more so when it's parked than it does going down the road. So now mine stays in the garage and will be getting a soft top in the future. I've heard they leaked from the factory. Just trying to provide some expectation management!
01-05-2013, 12:05 PM | #4 |
The 'tees' are there for alignment, sorta takes the pressure off the glue until it sets up. Ive used 3 M with great success, but there is a method to using weatherstrip sealant. Not using it will set you up for failure
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
01-05-2013, 12:55 PM | #5 |
I got mine from lmc as well. Harley, where did you get your T style?
Jaros, good info. But I would still like using the t's. |
01-05-2013, 03:01 PM | #6 |
Yep, use the 'tees', it will ease the pain of installation
01-05-2013, 05:46 PM | #7 |
So I need to poke holes for the t's? This strip has no holes or t's
01-05-2013, 08:09 PM | #8 | |
Weatherstrip should have holes
01-05-2013, 09:57 PM | #9 |
yep, no holes.
Tried buying t's at local parts store, nope. I now see lmc sells them. Can anyone tell me how many I will need? Last edited by Dale99; 01-05-2013 at 10:05 PM. |
01-06-2013, 09:56 AM | #10 |
Mine has 7 clips/side. It's a double wall and I'm not sure if the single walls are different. I think I got my seals from GMC Pauls. I generally try to get parts from the supporting vendors. I didn't use any adhesive on my seals and maybe that's the problem with mine?
01-06-2013, 10:38 AM | #11 |
thanks!
01-16-2013, 01:02 PM | #12 |
Bringing this back to the top. Is the rear hatch seal the same design? Its leaking as bad, or worse then the doors.
01-16-2013, 02:49 PM | #13 |
update for anyone who may search on this later. GMCPauls is one of the dealers who sells the window seals with the holes for the "t" hold downs. However, they said they do not have a source for the the "t"s. I see lmc sells these. I'm hoping I can get my stocks out w/o snapping any.
:edit: correction on this. GMCPauls SAYS they have holes. Got them in today, it is precision gaskets, and they do NOT have holes in them. Last edited by Dale99; 01-19-2013 at 07:02 PM. |
01-16-2013, 07:54 PM | #14 |
The single wall tops have a rail that the weather strip goes into and the double uses the push in t's.
Atleast mine do. Posted via Mobile Device |
