Old 01-05-2013, 07:32 AM   #1
tjmeadows
3 speed manual with complete OD setup
I have a 3 speed manual trans with OD,linkages, cable, handle and solenoids out of a 69 CST 10, for sale for $500 obo, in good working order. I also have a 69 lwb rolling chassis with 307, and all the chassis components with a 4.10 rear end.
tjmeadows is offline   Reply With Quote
Old 01-05-2013, 01:06 PM   #2
tjmeadows
Re: 3 speed manual with complete OD setup
I've heard this OD setup is hard to find, obviously not
Old 01-05-2013, 02:22 PM   #3
70blackfish
i dont know anything about this trans, tell me more....
shipping to 93063?
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 01-05-2013, 02:25 PM   #4
70blackfish
pictures? i have a 3 on the tree,
will it bolt right in?
Old 01-05-2013, 02:44 PM   #5
tjmeadows
This was a factory OD transmission that was cable operated from inside the cab, your 3 on the tree operates normally while disengaged, but if you engage the overdrive handle, mounted on the bottom of the dash, you get an overdrive addition to third gear. There is also a solenoid, mounted on the carb linkage, to act like a passing gear, at full throttle the transmission goes back into standard 3rd gear.
Old 01-05-2013, 02:54 PM   #6
70blackfish
So drive shaft is shorter, but same yoke?
How much overdrive is it? .70 or??
Old 01-05-2013, 02:59 PM   #7
tjmeadows
Yes I think so on the driveshaft, think its a 21% of, don't hold me to that...
Old 01-05-2013, 05:23 PM   #8
capev86
the OD unit is the same length as the regular Saginaw tail cone, so no cutting the drive shaft shaft or changing mounts is required if your truck had a 3spd manual to begin with. the center shaft in the trans is different at the back end to fit the overdrive. the R10 unit used on Chevy's had a .70 ratio, whereas the more rugged R11 unit found on Fords had a .72 ratio. they are not a direct swap, unfortunately.
you can swap the center shaft and drill out the hole for the reverse lock out rod to adapt this setup to a Saginaw 4spd. there is such a 4spd all built and for sale on eBay right now.
my 72 Suburban C20 has a 307 with 3 on the tree. i picked up one of these transmissions a couple years ago, but I need all the equipment to operate it. doubt you'd be willing to separate, so would you take $500 w/ shipping for the whole setup?.....if yes, I'lll TAKE IT!!!
capev86 is offline   Reply With Quote
Old 01-05-2013, 05:31 PM   #9
capev86
since we can't all have this one, there is a complete truck same setup ('69, 307, 3spd OD) on Craigslist in Florida right now. i wanted it, but that's a long drive for me.
http://staugustine.craigslist.org/cto/3437196816.html
Old 01-05-2013, 06:23 PM   #10
tjmeadows
I would take $400 and you arrange for the freight, that's a long wait to ship 100-125 lbs...
Old 01-05-2013, 06:25 PM   #11
tjmeadows
Or I have my entire 69 lwb, 307 and 3 on the tree for $1000
Old 01-05-2013, 08:41 PM   #12
capev86
pm me your paypal info and i will get the $400 sent. oh...and send me your address also so i can make shipping arrangements. that part might take a couple days.
Old 01-05-2013, 09:22 PM   #13
mvesr
If no one takes it let me know
Thanks-Mika
mvesr is offline   Reply With Quote
Old 01-05-2013, 09:26 PM   #14
capev86
sorry, just sent payment!
Old 01-05-2013, 10:18 PM   #15
mvesr
Thanks-Mika
Old 01-05-2013, 10:20 PM   #16
tjmeadows
Transmission sold!
Old 01-05-2013, 10:22 PM   #17
capev86
going to give UPS a call when i get a chance, unless someone has a better idea. i've had terrible luck with Fedex, so not going that route!
