01-05-2013, 10:16 AM | #1 |
How much room between inner and outer skin
Could some one tell me how much room there is between inner (inside cab ceiling) and outer (top of cab). My upholster needs to know if there is enough room for his spring clips to hold the head liner insert in place.
Thanks for the help |
01-05-2013, 01:45 PM | #2 |
UCA63
Re: How much room between inner and outer skin
In the center they darn near touch,enough room for the anti-vibration pad or?? to fit in there.
Of course more room down the sides and at the back. Still very close if you're staying in the center rectangle. T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
01-05-2013, 02:25 PM | #3 |
when i did my headliner..i drilled and there is not enough in the Middle to run any type of screws...but there was enough around the edges if you want to see mine..I will bring it to your place
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
