Old 01-05-2013, 04:00 PM   #1
dropanddrag71
dropanddrag71's Avatar
Radiator overflow questions, advice, pics.. help
I just installed a new radiator in my 70 c 20 with a 350. The truck has a very bad and damaged universal plastic overflow that i need to replace. I see nice stainless steel ones on the internet but i have a few concerns.
First, what size should i buy, i see them rated in ounces. Next, can i see what your running and where you installed it, Pics, pics, and more pics!! I'd like to see some ideas!! Under the hood is nice and clean, but by no means a show stopper!!! Truck is driven alot in the Florida Heat.
" You are only coming threw in waves,... Your lips move, but i can't hear what your saying"
dropanddrag71 is offline   Reply With Quote
Old 01-05-2013, 04:27 PM   #2
rsavage
rsavage's Avatar
Re: Radiator overflow questions, advice, pics.. help
I don't run an overflow can on any of my trucks. They didn't come with them. Good radiator, good 15lb. cap, shroud, 160 or 180 stat and a good clutch fan spaced into the shroud correctly and I don't have any overheating/purging issues.
Edit Note: There may have been some trucks built for the military with a coolant tank. There is a photo of a military ordered truck SPID in another post that indicates some sort of tank - but to date I haven't seen a photo of one and it is my belief that they were not available on a regular production truck.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 01-05-2013, 04:35 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
^^ They didn't come with radial tires, either...
dropanddrag71, check this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=290165
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 01-05-2013, 04:49 PM   #4
rsavage
rsavage's Avatar
My point was that if the cooling system is up to snuff in all respects, an overflow system shouldn't be necessary. Although they came with non radial tires, they didn't purge coolant every time they were shut off either.
1961 C1 Corvette
2021 Durango RT 5.7
Old 01-05-2013, 05:19 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Many people are doing fine without a recovery tank, and that's a good thing. I see it as a cheap, easy improvement.... and if for some reason it runs a little hot on occasion, coolant won't be dumped on the ground.
- Mike -
RIP El Jay
Old 01-05-2013, 07:19 PM   #6
BigCountryx
BigCountryx's Avatar
I just mounted a nalgene bottle under my battery tray. Can't be seen and very simple instal. Two holes in lid, line from radiator goes through one hole and all the way to the bottom of the bottle. A second line that only extends into the bottle about an inch runs down through the hole in the inner fender. Works fine for the just in case situation.
1972 Pale Yella 2WD Blazer ..... 350HO/700R4.... '68 Clipped
1970 Original Paint SWB Farm Truck ..... 5.3/4L80.... 2x HRPT Participant
BigCountryx is offline   Reply With Quote
Old 01-05-2013, 07:58 PM   #7
Andy4639
Old member
Andy4639's Avatar
Wink Re: Radiator overflow questions, advice, pics.. help
The older style radiator had the water level about 2-3 inches below the cap so the radiator it self was the over flow. It allowed for expainsion inside the radiator. That was how the system was built back then. If you didn't keep a good eye on the level though it could have gotten low and you run a risk of having to low of coolant in the system. These systems weren't meant to have pressure caps on them either.
The expansion tank retains coolant in a reservoir that's been forced out of the car's radiatior under pressure. As you run your car, the temprerature of the coolant circulating through the water jackets naturally increases causing increasing pressure in the cooling system. When the pressure builds to a high enough point, the radiatior cap allows that pressure to escape into the coolant reservoir through a small black rubber tube, called an overflow tube connected by the neck of the radiator to the expansion tank. Most of the coolant that is forced into the expansion tank returns to the radiator naturally after a few hours or when the engine is cold. If you had no expansion tank on your car, then the coolant that was released under pressure would spill out onto the road.
Here is some good reading for you.
http://www.procarcare.com/icarumba/r...a_cooling1.asp
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-05-2013, 08:18 PM   #8
DPowers
DPowers's Avatar
http://www.persh.org/pickup/BurpTank.htm
DPowers is offline   Reply With Quote
Old 01-05-2013, 10:09 PM   #9
Darren MagooGardner
I saw this one today at UPULLIT, It looked factory, but is it?
Darren MagooGardner is offline   Reply With Quote
Old 01-05-2013, 11:08 PM   #10
rsavage
rsavage's Avatar
Not factory. They didn't come with one.
Section 6K of the Chassis Service Manual:
"All Chevrolet trucks have pressure type engine cooling systems with thermostatic control of coolant circulation. The cooling system is sealed by a pressure type radiator filler cap."
"All truck cooling systems are pressurized with a pressure cap which permits safe engine operation at cooling temperatures of up to 247 degrees F"
1961 C1 Corvette
2021 Durango RT 5.7
Old 01-05-2013, 11:21 PM   #11
AirSpeed
AirSpeed's Avatar
I bought an extra windshield washer tank and mount from LMC for about $15, it works great and even comes with a cap and tube that reaches the bottom of the tank so it can suck up the coolant.
AirSpeed is offline   Reply With Quote
Old 01-05-2013, 11:42 PM   #12
rsavage
rsavage's Avatar
Nice idea and it would look about as factory as is possible.
1961 C1 Corvette
2021 Durango RT 5.7
Old 01-06-2013, 10:19 PM   #13
hayhauler71
hayhauler71's Avatar
one from summit racing
Fuzzy
hayhauler71 is offline   Reply With Quote
