Old 01-05-2013, 05:19 PM   #1
JonCheun
Exclamation 68 won't go passed 60mph
I have a 1968 C10 Stepside w/ a 350 crate engine that has 15000 miles and gear vendor overdrive. I just put a new Holley manual choke 2 barrel carb on it. Yesterday I was on the interstate and when I got up to 65mph it would hold but then start to jerk and go down to 55mph then to 50mph. It runs fine when I am on surface streets and going only up to 45mph but once I go to 60mph it starts to do it again. Today, I'm going to change the spark plugs.
Anyone Have any ideas or have experienced this same problem.
-Jon Cheun
JonCheun is offline   Reply With Quote
Old 01-05-2013, 05:30 PM   #2
Re: 68 won't go passed 60mph
Is the choke open?
Old 01-05-2013, 05:37 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Ignition could be the culprit or it may be fuel related. Weak fuel pump, restricted fuel lines, filter clogged up, or float problem -fuel logged or has hole depending on what kind you have.
Other possibilities are distributor or may timing. Hard to say until you start eliminating the possiblities.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 01-05-2013, 05:39 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Forgot to say welcome...
Also, don't know if you're aware of it but have a double post. You may want to delete the other one.
06 Trailblazer
Old 01-05-2013, 06:08 PM   #5
ol_skool_chevy
ol_skool_chevy's Avatar
This might sound silly but is the fuel filter Inside the Carb in backwards...sound like its loosing flow...
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 01-05-2013, 07:59 PM   #6
DorianB
DorianB's Avatar
yeah, I was thinking the same sort of thing.. I had that issue with a wrong fuel filter in the carb, when it was tightened in, it crushed the filter restricting the fuel flow.
In my opinion, it works best to have the seat out so you have room to flop your body around while standing on your head. -ashx2
DorianB is offline   Reply With Quote
Old 01-05-2013, 08:45 PM   #7
JonCheun
Thank You Everyone for your suggestions.
My fuel pressure gauge read only 1 psi when it should be around 5-7psi.
I had a clogged fuel filter so I replaced it.
Thank You for the welcome. Sorry if there is a double post. I am still learning how to use this forum.
Here is a photo of my 68
Old 01-06-2013, 12:27 AM   #8
71veronica
71veronica's Avatar
NICE stepside love the paint
71veronica is offline   Reply With Quote
Old 01-06-2013, 01:11 AM   #9
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Nice truck! Glad you found the problem. And welcome to the site!
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 01-06-2013, 01:53 AM   #10
elf w/capital T
Sweet truck glad ya got it fixed!
elf w/capital T is offline   Reply With Quote
Old 01-06-2013, 01:57 AM   #11
nds1968
nds1968's Avatar
Nice truck So how fast does it go now
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
