Old 01-05-2013, 06:59 PM   #1
gringoloco
A guy with a truck
gringoloco's Avatar
Name That Truck Part
At risk of appearing a buffoon, can someone please enlighten me to this component's name/description/purpose? All it was good for was a fat vacuum leak before I capped it off.
Never had a truck this original before, so I'm kinda stumped. Chasing vacuum leaks during a tune up and found this mystery part sucking wind. '72 Blazer, 4wd, 350/350, A/C. This is bolted to the intake manifold, on the passenger side, just behind the choke:
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-05-2013, 07:51 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Name That Truck Part
From what I have read about the system I believe that might be the TCS vacuum switch.
It controls vacuum to the distributor to prevent vacuum advance until engine warm up.
TCS stands for transmission controlled spark. I think the green wire goes to the temp sender and the red wire goes to key on power.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-05-2013, 08:07 PM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks! That makes sense. The tee before it is branched to the dizzy, so it is currently bypassed. Wonder where that teed line was supposed to go? The tee is an integral part of the assembly, not something someone put in there.
-Chris
Old 01-05-2013, 08:08 PM   #4
JimKshortstep4x4
In addition to the engine temperature as part of the control on the vacuum switch, the transmission has to be in high gear in order for the vacuum switch to allow the vacuum advance to operate.
There should be a switch on the transmission that is wired into the emission control system, (TCS).
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 01-05-2013, 08:47 PM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
Learn something new every day... Was this a '72 only thing? I thought non-California trucks were safe from this mess
-Chris
Old 01-05-2013, 09:05 PM   #6
da-burb
"Ochre Ogre"
da-burb's Avatar
I have seen it in that location on 1970's. My 71 suburban has it mounted to the front of the carb (same place as the 72's I have seen it on).
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 01-05-2013, 09:07 PM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
My 1972 GMC had the TCS system on it when I got it. My truck has been in WA state for its entire life. I disabled it, and removed it.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 01-05-2013, 09:26 PM   #8
custom1970
Member
custom1970's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=464103
Try the above thread if you want some more info. Hope the link works, doing this from my I pad and its a little harder to paste things.
But, yes it's part of the TCS system.
1970 CST LB Fleetside, 402 BB, PS, PB,AC
1968 Firebird 400 conv.
1965 Chris Craft 17' wood ski boat (SN #0001)
custom1970 is offline   Reply With Quote
Old 01-05-2013, 10:27 PM   #9
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks everyone. I've done a little research on the system and it seems capping the solenoid was the right thing to do
-Chris
Old 01-05-2013, 11:44 PM   #10
2500HD
2500HD's Avatar
It looks like I have one also. i have been wondering what it is. This is a 70 BBC 400 with California emmisions. I would like to delete....... what am i going to hurt and how would i go about it?
1970 Custom Original 400/400
Now ZZ454/4L80E/Edelbrock Pro-Flo 4/3:73 Eaton Posi
PS PB and cold factory air
Early Classic 4.5/6
Front 20X8.5 Riddler 4.75 inch bs Pirelli 255/40/20
Rear 20X10 Riddler 5.5 inch bs Toyo 295/40/40
Rear end is original wide 6 lug converted to 5 lug
2500HD is offline   Reply With Quote
