Old 01-05-2013, 08:20 PM   #1
arider278j
4l60 prob
I have a 04 5.3l truck motor with 4l60 trans in my 68. Driving truck last i lost 3rd and 4th gears. Drove home in manual 2nd. I have had this motor and trans in for about a year now. Any trans guys out there that have seem a common prob cause this? No i have not checked for any codes. My scanner is at work. Did pin out shift solenoids through pcm connectors all solenoids had 3k ohms. Thanks Kevin
arider278j is offline   Reply With Quote
Old 01-05-2013, 08:32 PM   #2
arider278j
Re: 4l60 prob
Ok did some more searching sounds like 3-4 clutch pack out bummer
Old 01-05-2013, 09:08 PM   #3
Hart_Rod
Hart_Rod's Avatar
Re: 4l60 prob
How many miles does it have on it?
Hart_Rod is offline   Reply With Quote
Old 01-05-2013, 09:41 PM   #4
ls1nova71
ls1nova71's Avatar
Re: 4l60 prob
Check engine light on? Also is it starting in first and shifting to second and that's all or is it starting in second?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-06-2013, 03:31 PM   #5
arider278j
Re: 4l60 prob
motor and trans per wrecking yard had 77000 miles so now prob about 83000.
No check engine light, i will check codes monday after work when i can bring my scanner home. Starts in first shifts to second then neutral. Engagement into gear firm 1-2 shift is firm no flare. Heck i could burn the tires first and second. The weird part is have drive it easy and all the shifts have been firm. never felt that any shifts had any flares. I remember in the late 90s the first gen 4l60 would either stay in first? or maybe had 1-2 shift when trans lost bat + power.
Old 01-06-2013, 03:43 PM   #6
ls1nova71
ls1nova71's Avatar
Re: 4l60 prob
Im not a trans guy, but if its going into neutral it sounds like an internal transmission problem, not a wiring or PCM problem. I believe if the trans has no power it will default to only second.
Old 01-06-2013, 06:24 PM   #7
arider278j
Re: 4l60 prob
Ya i kinda figured that. But one can always hope. O well guess i am rebuilding a 4l60 in the next few weeks. Thanks guys
