Old 01-05-2013, 09:14 PM   #1
McNutty
McNutty's Avatar
Help with cheepest way to fit fat tire on 84.
I been looking and everything is over 1500 bucks to get a fatter tire on my 84. I do not want to cut the rear end down or move the frame rails. I would like to move the leaf springs and that would give me a lot more room! Would moving the leafs to inside the frame rails work? Other options?
McNutty is offline   Reply With Quote
Old 01-05-2013, 10:03 PM   #2
Aaron_L
Re: Help with cheepest way to fit fat tire on 84.
Yes if you swap the hangers & shackle mounts side to side, mounting the brackets to the inside of the opposing frame rail. You'll either have to trim the inside of the rail down or space the hangers out so the leaf springs won't hit the frame. Then you can run a 15x12 with 7.5" backspacing with a 29x15.59 tire. You'll need to roll the fender lips. But even then you're still looking at about a grand in tires & wheels, not counting if you're paying for someone to do the work. You'll be close to $1500 if you're buying everything new.
Aaron_L is offline   Reply With Quote
Old 01-05-2013, 10:08 PM   #3
cmyc5575
What size do you have on the back now?
cmyc5575 is offline   Reply With Quote
Old 01-05-2013, 10:10 PM   #4
McNutty
McNutty's Avatar
295/50/15 on a 8'' wheel, i want to be able to run a 12'' wheel tucked.
Waiting on an upload of a pic of it now.
Old 01-05-2013, 10:16 PM   #5
fast85
How big do you want to go?
15x12 with 7.5 bs with 3" mini tubs and 315/60 drag radials will fit though very tight.
15x10 with 5.5bs with no mods and 295/65 dr's
all with a very low stance
Either way measure your truck as some trucks are offset to one side more than the other.
fast85 is offline   Reply With Quote
Old 01-05-2013, 10:27 PM   #6
McNutty
McNutty's Avatar
Old 01-05-2013, 10:29 PM   #7
McNutty
McNutty's Avatar
As you can see with a 8'' wheel with 295/50's are sticking out to far to tuck now but I do have plenty of room to the inside and even more if I move the tubes in! The truck just sets way to high for me and I want to flip the axle and tuck a wider tire.
Old 01-05-2013, 10:39 PM   #8
fast85
You can flip the axle and do springs and spindles to go 4/6. when i lowered mine 15 years ago belltech offered a 3" spindle and 1" spring. now i think its 2.5 and 1.5 which should work better to raise your lower a arm height. 12s look killer with mini tubs and the handling doesn't suffer.
Old 01-05-2013, 10:47 PM   #9
INSIDIOUS '86
INSIDIOUS '86's Avatar
If you want to hook then get some steelies and m/t drag radials. Change them when you race or whatever
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 01-05-2013, 11:05 PM   #10
69GMC910
MOTORHEAD!
69GMC910's Avatar
I run 30x12's on my 15x10 rallys and they dont stick out or rub anywhere. I believe they are 4.5" backspace...
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 01-05-2013, 11:11 PM   #11
69GMC910
MOTORHEAD!
69GMC910's Avatar
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 01-05-2013, 11:11 PM   #12
McNutty
McNutty's Avatar
I thinking of painting the entire truck silver, then all chrome is going to be flat black. I want to drop the front another 1'' or so and rear needs at least 5''. I think i wanna run a 15x10 front and 15x12 rear! The wheels will be black as well! The truck now has 2'' drop spindles and 2'' drop shackles i think!
Old 01-05-2013, 11:27 PM   #13
cmyc5575
You shouldnt have any problem flipping the back with the 15x8's now and you could very well possible get away with a 15x10 in the rear with out having to. 12's when your going to have to start cutting away the fender lips and then tub the bed about 3 inches. Correct me if Im wrong someone but when you lower the truck the wheel and tire slightly change inwards toward the truck.
Old 01-05-2013, 11:37 PM   #14
McNutty
McNutty's Avatar
Yeah im going to move the tubs in as far as the frame rails to just have the room. Also will trim the fender lips!
Old 01-05-2013, 11:54 PM   #15
McNutty
McNutty's Avatar
Ugh......... Will a 325/50/15 tuck on a 10'' wheel with 3''3/4'' back spacing?
I really really want to run these wheels!! Think I might run a 15x5 front and 15x10 rear! Cheap wheels but i freakin love the looks!
http://www.cragarwheel.com/products1...rSeries69Delux
Old 01-06-2013, 01:40 AM   #16
bdiamond
3 1/2" backspace on a 10" wheel won't. I think it'll take at least 5".
bdiamond is offline   Reply With Quote
Old 01-07-2013, 09:39 PM   #17
baclay9
You need 5" backspacing to tuck on a 10" wheel. I have 295/50/15's on a 10" wheel with 5" backspacing and 7" of rear drop. I have 1/4" clearance to the fender lip and about 1" clearance to the inside wheel tub.
baclay9 is offline   Reply With Quote
Old 01-08-2013, 01:03 AM   #18
McNutty
McNutty's Avatar
Yours "c" notched?
