01-05-2013, 10:46 PM | #1 |
Fuel tank selector switch....!!!!!
My V30 tbi with dual tanks has a jumper wire in the fuel tank selector switch harness. I bought a new switch in place of the jumper and when I put it in it would stay on either tank. I have to hold the button on either left or right tank for the truck to stay running. If I let off the engine dies. Ive tried several switches, Im not sure what else could be the problem or if I have the wrong switch. It is switching from either tanks and reading correctly. I cant drive while holding the switch and tring to shift gears and stear with only two hands.lol Any suggestions?
01-05-2013, 11:03 PM | #2 |
Re: Fuel tank selector switch....!!!!!
Glue...
What year and pin style is the switch? Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
01-06-2013, 01:01 AM | #3 |
Sounds like you got the momentary switch. You need the switch that stays on either left or right tank. The tbi trucks need the current going to the pollak valve and the sending units constantly. Otherwise, the sending units lose voltage and shut down. I went through the same thing a couple times before I finally went to NAPA and got the right switch.
01-06-2013, 01:17 AM | #4 |
Moderator
You don't have the correct switch.
The 82-91 tank switch should be the same part. Many parts houses sell an incorrect 3 position polarity reversing Double Pole (Momentary ON)-OFF-(Momentary ON) switch. It's the wrong part. You can get away with it on the 82-86 dual tank motorized valve system but it's still the wrong part. The correct switch for all dual tank 82-85 CK & 86-91 RV models is a 2 position polarity reversing Double Pole ON-ON switch. Meaning the contacts stay closed in each position and it does not spring back to a center OFF position.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
01-06-2013, 01:29 AM | #5 |
i have a question too, i changed both sending units, valve, switch. and everything worked fine for a while. now i have no gas gauge and im not sure if its switching tanks? ive been only on the left tank for sometime. i just asumed it was the wiring? could it be the switch on my truck doing this too? mines an 82. any help would be appriciated. sorry to post this on someone elses question. just wanted input while were on the topic!
'82 c10 shortbed drag truck '82 GMC 3500 Dually DD scrap truck '55 Chevy 210 4 door sled '65 VW Bug Rat Rod |
01-06-2013, 01:44 AM | #6 | |
Moderator
Do you have the single wire valve or the motorized valve with the 6 tower WeatherPak?
01-06-2013, 01:55 AM | #7 |
ill have to look at it tomorrow to tell you i dont remember, i believe it had a plug with mutiple wires. so probably the 6 wire. ? so switchs from 81-85 are different from 86-91? because of carb vs. tbi?
01-06-2013, 06:30 AM | #8 | |
Moderator
The same maintained position polarity reversing switch should be used from 81-91. Even though you can get away with using a momentary switch on the 81-86 you'll have to hold it down long enough for the valve shuttle to make a complete transit. If the valve shuttle is not traveling all the way to the stop the gauge will not switch.
And please let us know if and how your repairs were successful. Last edited by hatzie; 01-06-2013 at 06:50 AM. |
01-06-2013, 09:04 AM | #9 | |
Desert |
01-06-2013, 11:22 AM | #10 |
cool thanks Ill have to wait till monday morning but Ill try it out. Our good parts stores close half day saturdays and sundays. I thought that was my problem but Oreilly advance and auto zone all said this was the correct switch. Ill look for the maintained switch if not Im gonna have to rigg it up some how.
01-06-2013, 12:13 PM | #11 | |
Moderator
Grab the '82 GMC Service Manual from the link in my signature. On the bottom panel of page 1364 you'll find the gasoline engine dual tanks wiring diagram for 1982. Any of the '81-'91 wiring diagrams gas or diesel will show the same selector valve internal electrical detail as they all use the same valve... Look at the "Fuel Tank Selector Valve & Meter Switch" internal detail box. I attached a quick drawing I made of just this detail.
01-07-2013, 09:54 AM | #12 |
Thanks again, Great explanation.
Desert |
01-07-2013, 11:26 PM | #13 |
Thanks guys the maintained switch worked! It switches from left to right fuel tank great. Now all I need is state inspection, for now. Then Paint, new custom flatbed,motor overhaul, pipes , interior,etc.... This project has just begun.
