01-05-2013, 10:56 PM | #1 |
Question of the day? 307sb, timing chain and valves
The timing chain on my 307 sb broke today! What are the chances I hurt the valves????
Posted via Mobile Device Posted via Mobile Device |
01-06-2013, 01:24 AM | #2 |
Re: Question of the day? 307sb, timing chain and valves
Is it a stock motor or has the block been decked or heads milled or anything like that? If it is a stock type motor pretty good chance you didn't hurt the valves. If it a higher compression and parts have been modified for less clearance there is a possibility that you hurt them . I would at the very least do a leakdown test on the cylinders. But would be better off pulling the heads and actually looking at the valves and checking them out. Hth Dan.
68 Chevy c10 longbed 307 with 305 H.O. heads,edelbrock performer intake,edelbrock performer plus cam,hei,Holley 650 double pumper and th400. Daily driver. It hauls butt,it hauls my butt where I need to go |
01-06-2013, 01:44 AM | #3 |
I've never seen a stock SBC that damaged valves when the timing chain let loose.
01-06-2013, 10:44 AM | #4 |
You asked for chances I'd say slim at best none at least. Time it up put a chain on it and fire it off for a 'nother couple hundred thou. Jim
01-06-2013, 01:25 PM | #5 |
It is a stocker 307...I feel a lot better now! Thanks guys
01-06-2013, 01:31 PM | #6 |
I had a customers 307 that bent the valves one time. Ive had plenty that didnt. If it wiped out all the teeth on the plastic spocket you need to drop the pan & clean it out. I have seen them plug up the oil intake & ruin the engine.
01-08-2013, 06:55 PM | #7 |
well guys it was worse than i was expecting, nine total teeth broke and worse of all it hit the valves....sucks because i just got this truck a month ago! here's a picture and yes that is PICACHO!!!!
