Old 01-06-2013, 02:02 AM   #1
yossarian19
Neutral Safety / PNP switch ??
I've searched a bit and am not finding the info I am looking for.
What I think I remember reading is that the PNP switch has three functions. One, reverse lights. Two, keeps engine from starting in anything but neutral or park. Three, adjusts idle speed by 100 rpm or so depending on if you are in neutral or drive.
The GM rep at SEMA said the PNP wasn't really necessary for a swap.
The harness I have uses 2 connectors for the PNP switch. Both are basically toast.
So at this point, do I get rid of the PNP wiring? If so, can I do anything to get my 100 rpm idle increase while in drive?
What else am I missing?
yossarian19 is offline   Reply With Quote
Old 01-07-2013, 03:56 PM   #2
OldCreek
OldCreek's Avatar
Re: Neutral Safety / PNP switch ??
Whether the 100rpm info is true or not, I suspect you could find the two connectors at a auto salvage or online. There are websites that will sell them. Moreover, you could probably go to a Chevy dealer and have them order these parts for you.
I have heard of guys using the stock pnp switch on the column, only. I use both... I wire my reverse lights and ignition from the stock column switch and leave the 4l60e tranny switch connected to the pcm. My knowledge on this subject is limited so do some more research...
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 01-14-2013, 01:09 PM   #3
mrhurt73
i am not sure of the exact pin-out, but i do know that the connection to the 4L60E tranny requires heat to get connectors loose.
found that out on my build after i almost destroyed the connector.
add heat they come apart easy.
My Projects-
http://67-72chevytrucks.com/vboard/s...d.php?t=557301
Quest for Hot Rod Power Tour 2013.
http://67-72chevytrucks.com/vboard/s...d.php?t=543735
my 85 GMC 2wd to 4wd conversion for the wife.
mrhurt73 is offline   Reply With Quote
Old 01-14-2013, 02:23 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I don't run reverse lights or an NSS/PNP. Then again I didn't run seatbelts, hood, or winshield for a while
IIRC the "100rpm" thing is somewhat true, tho I'm not sure if it actually makes a difference. My tuner said that it was a function of load and the knock count /lockup. It only does so to prevent feeling the "clunk" into drive, and the occasional "dip" in rpm from the drivetrain loading up. When I put mine into gear, you feel it load up, the rpm MIGHT dip by about 50 for half a second before it catches itself. Thats it.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-15-2013, 07:26 AM   #5
mcmlxix
Collector of Projects
mcmlxix's Avatar
check out this thread HERE
Rich
1972 K5 Blazer CST Click HERE
Old 01-15-2013, 08:16 AM   #6
homemade87
Yossarian19, I Believe the gm rep was correct. I just used the factory wiring for the reverse lights an saftey neutral. I have a 04 pcm and my tunner told me it watches for load. When it sees load it adjusts accordingly when it sees a rpm drop ( a/c , put in gear ). Not sure what year you have but it may do the same. Might want to look into it.
homemade87 is offline   Reply With Quote
Old 01-15-2013, 10:37 AM   #7
1970 C10 MJW
1970 C10 MJW's Avatar
subd
70 C10 working on a LSx swap
4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol
1970 C10 MJW is offline   Reply With Quote
