Old 01-06-2013, 02:33 AM   #1
v62go
how much does your ls1 67-72 truck weigh?
lets hear it...
v62go is offline   Reply With Quote
Old 01-06-2013, 08:53 PM   #2
v62go
Re: how much does your ls1 67-72 truck weigh?
nobody has ever weighed their truck?
Old 01-06-2013, 10:09 PM   #3
1970 C10 MJW
1970 C10 MJW's Avatar
the LS engines if iron i believe are about 100 pounds lighter then the iron headed sbc. and the aluminum block ls engine i believe is 150 pounds? you could do some simple google searches on ls engines... then just figure out how much your truck weighs and subtract the appropriate amount of weight
70 C10 working on a LSx swap
4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol
1970 C10 MJW is offline   Reply With Quote
Old 01-06-2013, 11:57 PM   #4
v62go
i weighed my 69cst shortbed and it doesnt look right to me 3680lbs..pw steering and brakes,bench seat,ls1 with a auto on column th350....just seems heavy to me.
Old 01-07-2013, 09:48 AM   #5
68Stepbed
68Stepbed's Avatar
I'll have to look up my numbers. I had mine weighed at the Ride Tech booth in Sept. It went from just over 3700 with an iron head SBC/TH350 to around 3590 with the LS1/700R4 setup and went from an almost 70/30 f/r bias to under a 60/40 f/r bias.
I'll search and see if I can find the info.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 01-07-2013, 04:13 PM   #6
OldCreek
OldCreek's Avatar
Sounds about right to me. Old iron is heavy.
For reference, 2012 ZR1 Corvette is 3,333 lbs...
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 01-08-2013, 02:10 AM   #7
Wasted Income
Boosted Member
Wasted Income's Avatar
69 LWB Fleet
iron 5.3/4L60E, 12 bolt, 15" alum wheels, air ride with no compressor
3950 without me in it.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 01-08-2013, 04:19 AM   #8
crazy longhorn
Fabricate till you "puke"
My old longhorn,(alum head gen I), 4240, less driver & a full tank of fuel. I know you guys will say"WHAT"! She is pretty stripped, no heat/air, & running 1/2 ton underpinings, tilt front clip. No fiber glass, all steel, but I figure around 150 lbs off going 5.3 crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-08-2013, 09:40 AM   #9
68Stepbed
68Stepbed's Avatar
OK, here's the numbers.
Last year, with the iron head sbc, it weighed in at 3,737 lbs with a 62/38 f/r weight bias. With the LS1 setup, it's now 3,591lbs with just under a 60/40 f/r bias.
Matt
Old 01-08-2013, 02:09 PM   #10
Wasted Income
Boosted Member
Man, you shorbed guys are giving me hope for what my blazer might weigh when done.
Turbo diesel
