Old 01-06-2013, 10:54 AM   #1
54 chevy dually
54 chevy dually
I have a 54 Chevy 3800 flatbed. My goal for this truck is to lower it, keep the flatbed, and put a beefy 350 motor in it. My main problem is the big ugly split rims. I am having trouble finding eight bolt rims that will work. I found a 76 Chevy dually that I was thinking about putting the 54 body on, however after closer measuring I found the front end was quite a bit wider than the 54. I don't think the tires would fit into the fenders. Does anybody have any ideas that could help me accomplish what I want to do. Thanks
54 chevy dually is offline   Reply With Quote
Old 01-06-2013, 04:37 PM   #2
Trekster
Trekster's Avatar
Re: 54 chevy dually
The rims from the 76 should fit your truck. You may need to go with a bigger stud (9/16) size but they should work.
Trekster is offline   Reply With Quote
Old 01-06-2013, 08:57 PM   #3
54 chevy dually
Re: 54 chevy dually
Thank you, I will try them. That would be easier than swapping frames.
Old 01-07-2013, 11:32 AM   #4
54 chevy dually
Re: 54 chevy dually
Old 01-07-2013, 08:17 PM   #5
Trekster
Trekster's Avatar
Re: 54 chevy dually
That is a nice truck. I like it.
Old 01-07-2013, 08:24 PM   #6
54 chevy dually
Re: 54 chevy dually
Thanks, I have a lot of work to do yet.
Old 01-07-2013, 08:30 PM   #7
54 chevy dually
Re: 54 chevy dually
I like your truck as well. Are those original wheels? I also like your mirrors. What did the mirrors come off of.
Old 01-07-2013, 11:00 PM   #8
sqrlnts
Re: 54 chevy dually
Thats one awesome looking project! Enjoy
sqrlnts is offline   Reply With Quote
Old 01-08-2013, 12:11 AM   #9
Trekster
Trekster's Avatar
Re: 54 chevy dually
The wheels are newer one piece rims. Make sure you measure the ID of the rim to match it to your hub. A friend gave me the mirrors, I think they are called West Coast Jrs.
Old 01-09-2013, 11:24 PM   #10
54 chevy dually
Re: 54 chevy dually
Thanks for the advice trekster, the rim does fit but the studs like u said need to be bigger. I dont think that is a big deal but the id is also larger than my hub. I dont know if i can get some sort of adapter for the center hub or not. I did like the look it would give me with the 16 in. Rims though. I wonder if there is a way to get another hub assembly fabricated on to the 54? ;
