Old 06-09-2003, 12:00 AM   #1
bodad
Front End Question
I am unbolting the front end from a 71 chevy LB tonight and notice when I remove the 4 bolts that run horizontal through frame only 1 bolt hole looks like it is in the right place. The bottom two holes are wallowed out and one of the top holes looks as though a hole was punched through with a torch. The top hole is about 5/8" ahead of what looks to be the original hole. It is the same on bothe sides. Is there an explanation for this? Maybe a different front end was bolted up to it that didn't quite match up or what?
'70 SWB in cab off restoration
--'72 K5 Blazer, super sharp, like new For Sale $7900--
bodad is offline   Reply With Quote
Old 06-10-2003, 06:37 PM   #2
bodad
55 Views and no one has an idea? Here is a pic to help the cause.
Old 06-10-2003, 06:46 PM   #3
bodad
Well it looks like the pic will have to wait. Meanwhile, is there nobody here that knows what I am refering to?
Old 06-12-2003, 12:38 PM   #4
bodad
Here is the picture. Surely someone can answer this, three days and not one response.
Old 06-12-2003, 12:40 PM   #5
1971Stepside
Almost Satisfied
1971Stepside's Avatar
It looks like someone put a newer front end under the truck, but I can't say for sure.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 06-12-2003, 12:43 PM   #6
bodad
Is that what a newer frontend bolt pattern looks like? I haven't seen one so I can't tell.
Old 06-12-2003, 12:46 PM   #7
1971Stepside
Almost Satisfied
I believe the 73 and up crossmembers require you to enlarge the lower holes and make one new one. That would follow what has happened to yours. Someone like longhornmail will have an answer for you.
Old 06-12-2003, 06:01 PM   #8
bodad
So if it is a newer year front then how do I know what parts to by to replace. I am going to install dropped spindles and many new front end pieces but I need to know what year to buy for. Is there a way to tell what year the front end is from?
Old 06-12-2003, 06:31 PM   #9
crazy longhorn
Fabricate till you "puke"
bodad, I cant help too much with the holes, as I still have the orig crossmember on my 69. as a rule on the spindles, you need to go for the yr of the spindle, & replace balljoints,tierods to match. The difference from the 71-72 pcs & the 73 up pcs.....71-72 are the same ball joints & & tierod ends. 73 takes the same lower balljoint, but a different upper balljoint, & outer tierod end(the taper differs on the pins). If in doubt , i would go for the 73 up dropped spindle(they will probably be cheaper anyway), & order the tierod ends(outers), & ball joints to match does the truck have steel a arm bushings, or are they rubber? crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
