Old 01-06-2013, 11:49 AM   #1
bloodybigblock
bloodybigblock's Avatar
86 C20 5.3/4l60e swap, MANY QUESTIONS!
So ive decided that posting many threads were annoying and took up room for anyone else with their own questions. I have a 86 c20 2wd with a 454/th400. I found a 01 DBC 5.3 with harness for a great deal. I have searched and searched hours and hours but all i can find is 67-72 info. I plan on having a CAI, electric fans,and a true dual exhaust since this wont be a hot rod.
1. What motor mounts? I'd like to run the stock manifolds and i want to keep my a/c.
2. I plan on lowering the truck, will my truck pan cause issues? Is there motor mounts that can raise the engine?
3. Best place to send my harness and ecm?
4. If i do my own harness, can it be driven to get the tune an hour from my house?
5. Any issues with running strait manifolds to make it to the muffler shop?
thats all the questions i have for now. Any help would be appreciated. Im ready to start buying parts for this thing.
bloodybigblock is offline   Reply With Quote
Old 01-06-2013, 06:32 PM   #2
bohmankid
bohmankid's Avatar
Re: 86 C20 5.3/4l60e swap, MANY QUESTIONS!
1) There's a ton of motor mounts you can use. I personally used the adjustable Dirty Dingo mounts. They clear the crossmemeber but they're kind of expensive and won't allow you to use the AC in the lower stock location. I plan on moving my compressor to the top of the motor. The stock manifolds will most likely require the frame to be trimmed. Trailblazer SS manifolds are supposed to fit without issues.
2) if you're lowering the truck, you might want to look into putting a ls1 pan on the motor. The car oil pans are not as tall.
3) there are a bunch of places to send your harness or buy a new one. Hopefully someone else can chime in because I did my own. I sent my PCM to brenden at lt1swap.com to get codes deleted.
4) if you do your own harness, you also need the VATS deleted off your PCM before you can even start the truck.
5) I don't think you'll have issues running straight manifolds. Just don't drive too far and make sure the exhaust won't burn anything. It'll probly run like poo.
Good luck.
bohmankid is offline   Reply With Quote
Old 01-07-2013, 01:03 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
if you use ls adapter plates, you will use regular SBC mounts, as you would if your truck came with small block. As stated, stock truck manifolds will only clear on 1 side, TBSS manifolds or doug thorley swap headers are the most popular options
The stock truck pan will usually hang up to an inch over the crossmember, you can try the car pans, or the GM "hot rod" aka LH8 pan
for my swap, I went with a complete new harness from fuelinjectionconnection it made wiring about a 25 minute job, included mounting everything. I did not send my ecm out, instead having it tuned by a local tuner.
VATS will stop that from happening. You have 3 choices. Send the ecm out and have vats and emissions removed OR have it towed to tuner OR pay the tuner some extra cash to come to your house....its not an option for everyone, but some guys might be willing to. My tuner was.
You won't have 02's in place, and it will run like trash. I would avoid doing so unless its real close or you don't have another option.
in red
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-07-2013, 09:46 AM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
What he said! ^^^^^^^^^^^^^^^
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-07-2013, 01:16 PM   #5
mrhurt73
for TBSS manifolds refer to this thread. http://67-72chevytrucks.com/vboard/s...d.php?t=530623 i used them and they fit great, $120.00 delivered to my house.
i am betting you will like the f-body pan, i am going to have to use the caddy pan, but my crossmember is not factory. this thread has a bunch of part no for oil pans, http://67-72chevytrucks.com/vboard/s...d.php?t=558494
on the air conditioner, i wanted to use the 5.3L compressor so got one of these blocks, http://www.nostalgicairparts.com/air...ght-out-36.php
since Doc's Blocks is no longer in business, i found these guys.
My Projects-
http://67-72chevytrucks.com/vboard/s...d.php?t=557301
Quest for Hot Rod Power Tour 2013.
http://67-72chevytrucks.com/vboard/s...d.php?t=543735
my 85 GMC 2wd to 4wd conversion for the wife.
mrhurt73 is offline   Reply With Quote
Old 01-08-2013, 05:10 AM   #6
bloodybigblock
Good luck.
Is there a bracket that moved the a/c compressor that is somewhat cheap? I have seen a/c compressors in the stock location on our style trucks. I also do not mind trimming the frame for the 5.3 manifolds. Im sure a 3/4 ton frame can handle a small notch especially since the weight between a 454 and 5.3 will take some pressure off.
Old 01-08-2013, 05:14 AM   #7
bloodybigblock
Originally Posted by BR3W CITY View Post
in red
are the oxy sensors not in the stock manifolds? Any suggestion on how im suppose to have my exhaust done or a way i can drive it to the muffler shop? I was under the impression that if it was tuned, thatd you could drive it with strait manifolds/headers? Any comment on how i can keep my A/c? Thanks man
Old 01-08-2013, 09:45 AM   #8
Clyde65
Clyde65's Avatar
high mount compressor bracket here ( http://kwikperf.com/) you will also need a sanden compressor.
Clyde65
Rebuild of Clyde
support our troops!
Old 01-09-2013, 03:22 AM   #9
bloodybigblock
okay well imma have to find a style motor mount or adapters that work with the a/c mount in original spot. I cant see paying that to get a/c. Im sure there is a better way. Im definitely on a budget lol. Im sure someone will chime in on what mounts will work for me. Keeping my a/c and not spending a ton of money is in my way from buying what i need.
Old 01-09-2013, 09:11 AM   #10
Clyde65
Clyde65's Avatar
Give Clinebarger a message, he has a suburban ( 80's) that he put a 5.3 in a while ago, I bet he can help you a bunch.
Clyde65
Rebuild of Clyde
support our troops!
Old 01-10-2013, 02:14 PM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Nope, the front 02's are mounted in what would be referred to as the down pipe or B pipe. Unfortunately....my solution for this was like bringing a sledgehammer to a walnut cracking festival.....I went a bought a MIG.
The easiest option is to call your exhaust shop or a junkyard and see if you can get that pipe off a donor vehicle. You will need the flanges and a stub up pipe approxomately 6-10" long, it will contain o2 bungs. If you cannot find a stock one, you can buy (sometimes) or fab (what I had to do) a set of flanges and an exhaust stub, then weld the bungs in place.
Old 01-11-2013, 08:11 PM   #12
bloodybigblock
haha, well you did work. So HELL YEAH! i can just get the B pipe past where the 0xy2 sensor is. Thatll work right? The a/c is what sucks, im about to say piss on it, i have 4 huge windows that roll down haha
thanks for your help also clyde
Old 01-12-2013, 12:00 AM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Yes, if you can get one it will work just fine. You can always fab another or modify it. Were I to do it again, I'd consider going with stainless, but for cost it really hasn't seemed worth it.
Old 01-12-2013, 10:15 PM   #14
Hart_Rod
Hart_Rod's Avatar
There's a lot of great info here!
Hart_Rod is offline   Reply With Quote
Old 01-12-2013, 10:42 PM   #15
shortbed70
shortbed70's Avatar
Useful info as I hope to be gathering parts this spring!!!
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 01-13-2013, 10:41 AM   #16
High ho silverado
High ho silverado's Avatar
If u go to the lsx swap faq u can find tons of info, and parts lists that some guys have put together. As far as 2wd headers for under 300 schoenfeld has a set of long tubes that work really good, I used them on my 4wd and they worked as well and they have o2 bungs already in them. Holly has a sweet r4 compressed mount that mounts the compressor up high and u can use the 90-91 blazer factory hoses, the bracket is around 130 bucks and is aluminum like the other ls brackets the only catch is u have to buy a spacer kit if ur using truck accesories and its a little over a hundred by its self but looking at it u can make ur own spacers and save a little money. As far as using the factory ac go to glocks build and it lays it out pretty well on the best way to do it.
Dan G
Lift it, fat chicks cant jump!
83 Chevy shortbed 4x4: 6.0 ls powered
97 Chevy 3/4 ton ex cab 454: work horse
00 Chevy camaro: daily driver
83 Chevy 3/4 ton: dads old rig
High ho silverado is offline   Reply With Quote
Old 01-13-2013, 07:00 PM   #17
mrhurt73
here is the stub pipe cut off the donor truck that i am using. i have the TBSS manifolds and going to put these on and add to it with a little help from buddy with tubing bender.
My Projects-
Old 01-14-2013, 02:16 PM   #18
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
good deal, using those means you can use the stock style gaskets as well.
Old 04-13-2015, 01:40 AM   #19
iceship
Did you have to shorten driveshaft..
iceship is offline   Reply With Quote
