Old 01-06-2013, 12:15 PM   #1
kcfirstbuild
Best wrench to bleed Brakes.
OK so i have a 68 with front drum brakes and I'm having a hell a time bleeding the front. All i can get on the bleeder screw is a deep socket because the spindle is always in the way. I have tried a bleeder screw wrench way way to long wont even fit.
kcfirstbuild is offline   Reply With Quote
Old 01-06-2013, 05:16 PM   #2
Daddy Brim
Daddy Brim's Avatar
Re: Best wrench to bleed Brakes.
Had the same problem with my 67. Ended up replacing all 4 wheel cylinders. The new ones I got from Napa has longer bleeders that you can get proper wrench on. Maybe you can replace just your bleeders.
I'm sorry I called you stupid. I thought you knew already.
67 C-20 Custom Camper
68 Nova 396 it does wheelies
2005 Buick Century the one the wife drives
1989 Toyota Tercel to drive when I can't put gas in the first 2.
Daddy Brim is offline   Reply With Quote
Old 01-06-2013, 05:50 PM   #3
cdowns
cdowns's Avatar
if wrench too long cut it down to fit the job????/// iwas taught to finish the job
