01-06-2013, 12:54 PM | #1 |
2002 Silverado brake problems
Anyone here have issues with the brakes dragging. I replaced all 4 calipers and pads, pulled the front wheel sensors and cleaned them and put never seize on them and went for a drive and all 4 rotors were hot. I hate just changing parts but I think the ABS module is too blame as it activates coming to a complete stop and I can feel them pulsing when driving. I am going to pull the ABS fuse today and see if that helps but what are the chances it is the master and not the abs module.
03-03-2013, 08:37 AM | #2 |
Re: 2002 Silverado brake problems
Bump for a good question, I'm also interested.
Posted via Mobile Device |
03-03-2013, 09:16 AM | #3 |
Have you tried replace in the hoses? When i change caplier i also install new hoses. It could be anything from the master cylinder sticking to a bad abs pump or blockage in ghe lines
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
03-03-2013, 01:21 PM | #4 |
I guess I am going to drive with no ABS fuse for awhile. I replaced the ABS module yesterday and the brakes dragged as soon as I left the shop. I pulled the fuse and they were fine. All lines were bled and am ruling out a hose or master problem because it only happens when the ABS fuse is in. I may have gotten a bad ABS module but who's to know, I guess I drove for 20 years without ABS and am to frustrated to deal with it anymore now. I will change my front hub assembly's with Timken units later this year but until then I will deal with the ABS light on. To make matters worse I picked my truck up and never noticed the broken passenger mirror, someone must have bumped it, another 100.00 bill to the repair.
03-05-2013, 12:27 AM | #5 |
did you replace the abs control module or the whole pump?
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
