Old 01-06-2013, 02:59 PM   #1
Cmalone
Cmalone's Avatar
Motor mount question
Hey guys, I got a 67 with a 250. I am wanting to put in a 350 but the motor mounts on the 250 dont look like they will fit the 350? LMC shows the 250 and the small blocks use the same mounts? Can anyone help on this? Thanks.
Cmalone is offline   Reply With Quote
Old 01-06-2013, 03:01 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Motor mount question
They bolt on. The three bolt pattern is the same between the 6 cylinder mount brackets and the small block V8 engine block holes.
You just use the rubber part, not the steel bracket that goes between the six cylinder block and the rubber part.
Old 01-06-2013, 05:58 PM   #3
WIDESIDE72
WIDESIDE72's Avatar
I believe you need sb frame stands though...
WIDESIDE72 is offline   Reply With Quote
