At the junkyard, have a question
Will this clutch fan fit in my '68?
Donor is a '81 C10 with a V8. I have a 307. Posted via Mobile Device Posted via Mobile Device
It's not that I am apathetic, I just don't care. If your life is a joke, it appears death will be your punchline. |
Gone Fishing
Re: At the junkyard, have a question
I believe the bolt pattern is the same
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop ![]() 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
So long its a 18" or 17" I believe.
Posted via Mobile Device |
Your cleared for take off
Old member
Get the fan pulleys and anything else they have for that setup. It will be fine.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Thanks for the quick responses and info. Once I got it off I could see where the fan had been rubbing against the shaft. So, I didn't take it, but I'll know for next time.
Thanks again, -Stephen Posted via Mobile Device
