Old 01-06-2013, 05:20 PM   #1
mvesr
Power steering pump
Does anyone know if on a 1968 307 engine the alternator and the PS pump are on the driver's side of the engine. Maybe some has a picture. Looking at mine yesterday looks like the alternator would be in the way of the pump.
Thanks-Mika
mvesr is offline   Reply With Quote
Old 01-06-2013, 07:33 PM   #2
jwalk
What was I thinking?
jwalk's Avatar
Re: Power steering pump
The alternator and pump are on the drivers side.
Justin
'68 C/10 Custom Long wide bed
'78 GMC Sierra short wide
Project: Second time around...'68 short wide
http://67-72chevytrucks.com/vboard/s...d.php?t=423949
jwalk is offline   Reply With Quote
Old 01-06-2013, 09:23 PM   #3
mvesr
Thanks for the picture, it makes sense now.
Mika
Old 01-10-2013, 03:56 AM   #4
stsalvage
Scrapper 1
stsalvage's Avatar
on all my trucks i run it closer to the driver side the wire harness for repop harness from M&H don't stretch that far.here are some pics of brackets and how they look
stsalvage is offline   Reply With Quote
Old 01-10-2013, 04:07 AM   #5
stsalvage
Scrapper 1
stsalvage's Avatar
number #2 pick in from 1964--67 that was the old bracket the rest are from 1968--72 and every thing is done off the drivers head bolts really easy set up
Now i will show you the right pulleys to be used on your engine with a small nose 327 water pump that will keep all your belts in a line
Now here is another one you need to know cus it can hurt you kill you or just fu-k you up.Them flex fan throw them away they never cool your engine and seen so far 5 of them come throw the front hood one missed my friend bay 2 mins he was standing over the fan while he was revving it up.I'm just think full it messed up his new paint job and his hood instead or me holding his hand and watching him die in my arms.
You can use 7 blades from Ford or dodge 6 blades are more common but the 7 give you so much more cooling just look that one is a Ford with the thermal clutch that bolts the the fan there there factory alum blades with alum rib bits in to steel housing
