Old 01-06-2013, 07:19 PM   #1
Andy4639
Old member
Andy4639's Avatar
Cool Fixing oil leaks on my 305
Going to start this week on fixing some minor oil leaks on the front of the 305 to get it ready for the 3000 mile round trip to Texas and back in June.
I started today by putting it in the garage where I can work on it for the next few weeks without moving it. I got the air housing off so far. Just going to take my time and do a little at a time. Winter time so not much driving it anyway.
My plan is to take all the belts off and replace with new ones and keep the old ones for spares during the trip. I have oil leaking from the timing gear cover and front of the oil pan and on this model engine you have to take both loose to fix one are the other. So I'm going to replace both with new gaskets and sealer plus paint whatever I can. New cranck seal rear main seal the works. Going to pull water pump and paint it and clean up the front of the motor while at it.
New plugs wires and such also.
Anybody have any tips for me?
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-06-2013, 08:13 PM   #2
mrein3
mrein3's Avatar
Re: Fixing oil leaks on my 305
Originally Posted by Andy4639 View Post
[B][COLOR="Red"]
Good plan on keeping older stuff for spares for a long trip.
If your crankshaft oil seal is leaking, be prepared to replace the harmonic balancer, buy a repair sleeve, or an offset oil seal. I've done all three. Each one works. You'll know you need to do something if there is a groove in your balancer. I'd hate to see you do all that work and still have a leak there.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 01-06-2013, 08:32 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Fixing oil leaks on my 305
Yea I got the regular seal and my friend who is a mechanic told me once I get it apart to check it good. I plan to get him over to the house and look at it also. Thanks for the heads up though!
I'll be posting pictures as I go if I don't forget. I'm bad about getting started and not wanting to stop to take pictures.
Old 01-06-2013, 09:40 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Might be as easy to pull the motor and reseal everything.You would be able to clean/paint better also.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-07-2013, 12:21 AM   #5
Andy4639
Old member
Andy4639's Avatar
Wink Re: Fixing oil leaks on my 305
I thought about it but just don't have the equipmemt to do it.
Old 01-07-2013, 07:09 PM   #6
Andy4639
Old member
Andy4639's Avatar
Cool Re: Fixing oil leaks on my 305
Well I started on the truck today. Got the radiator, water pump off crank pulleys off. I don't have the puller for the balancer but I can get one in the morning. Going to jack the truck up and drain the oil and filter tonight.
I have to drop the oil pan to get all the leaks fixed so I'm doing the oil change as well.
I'll post the pictures here in a little while after I eat.
Old 01-07-2013, 07:28 PM   #7
Andy4639
Old member
Andy4639's Avatar
Talking Re: Fixing oil leaks on my 305
Looks like I'm going to have to pull the intake as well to get all the leaks fixed.
This may take longer than I had plan but it has to be done. Going to clean everything good and repaint it to I hope while I have it a part.
Old 01-07-2013, 07:44 PM   #8
67ChevyRedneck
67ChevyRedneck's Avatar
Ewwwwwwwwwwwwwwww
I just fixed the leaking water neck on mine.
My damn mustang hasn't leaked a drop of anything the first 6 months I bought it, then all of a sudden the trans pan is leaking, oil pan leaking, timing cover leaking... what the crap?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-07-2013, 10:19 PM   #9
Andy4639
Old member
Andy4639's Avatar
Originally Posted by 67ChevyRedneck View Post
Ewwwwwwwwwwwwwwww
What do you expect form a Ford!
For over 200,000 on the motor it's not to bad really!
Old 01-08-2013, 05:28 PM   #10
Andy4639
Old member
Andy4639's Avatar
I picked up a new water pump and timing gear set today.
Got the balancer off and got everything cleaned up to start back with now. I have a few days of painting and I need the radaitor fixed.
Balancer was fine along with the shaft. Just need seals and she is good to go another 200,000 I hope.
Old 01-08-2013, 06:03 PM   #11
Andy4639
Old member
Andy4639's Avatar
I just called griffin radiator company just to see what a radiator from them cost. Nothing fance mind you just the normal type truck radiator. Man was I surprised! $600.00 base price.
I know these are top of the line hand made but dang! I never thought it be that much.
Well I guess my old one will get took to the local shop and fix it.
Old 01-09-2013, 09:59 AM   #12
Lee H
Lee H's Avatar
Nice progress.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 01-09-2013, 03:40 PM   #13
Andy4639
Old member
Andy4639's Avatar
Thanks,
got the new timing set in and aligned correctly thanks to my buddy Bill for stopping by and making sure it was right.
Just taped off the front of the motor and used aluimnum foil to cover up stuff so I could paint it. Just came in to let the first coat dry before spraying another.
Old 01-09-2013, 06:23 PM   #14
GRX
GRX's Avatar
How do you like re-installing that timing cover without moving the oil pan? Fun huh?
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 01-09-2013, 08:41 PM   #15
Andy4639
Old member
Andy4639's Avatar
Well to be honest it wasn't as bad as I had been thinking it was going to be.
I cheated a little though. I loosened the front 3 bolts on each side of the pan just to give it some play. I took 2 small screw drivers and wedged in the front ends of the pan and it went right on. I used plenty of sealer also.
Time will tell. I have to pickup the new belts and radiator when it's done and fill it up with oil and water anti freeze and power steering fluid.
Old 01-10-2013, 03:01 PM   #16
Andy4639
Old member
Andy4639's Avatar
Well had a surprise for us this morning when we woke up! No hot water. The wife wakes me up at 6am after going to bed at 4am. No hot water. Well I get dressed and go look under the house and I have a small pond where the hot water heater pop off valve let go.
Anyway long story short. Got hot water back had to buy new heater.
I'm waiting on water to heat up to get a shower so I can go pickup belts to finish up the truck. Called about the radiator he said it would be done by 5pm. Got to be at work by 5 so I guess I'll pick it up tomorrow. May have this done by Saturday who knows.
Old 01-11-2013, 08:56 PM   #17
Andy4639
Old member
Andy4639's Avatar
Got the radiator from shop and put the belts on the truck. That all I had time for today before coming to work. Hope to get everthing tightened up and filled up tomorrow.
Old 01-12-2013, 04:50 PM   #18
Andy4639
Old member
Andy4639's Avatar
Not much done today. Changed out all the mounting bolts on water pump and alternator to Stainless Steal and adjusted all the belts tight. Time to get ready for work.
Old 01-14-2013, 12:26 PM   #19
Andy4639
Old member
Andy4639's Avatar
Got home this morning after working a 12 hr shift and got everything put back together. Filled the Power steering up, radiator and oil filter with 5w-30 snythitic oil. Jacked the truck up and turned the wheel a couple of times lock to lock. Set it back down and cranked it up and did the same thing. Then I let it run for about 20 minutes and checked for any leaks. Didn't find none so I think I'm good. Top everything off and called it good!Now it just needs to stop raining.
Old 01-14-2013, 11:58 PM   #20
GRX
GRX's Avatar
Cool deal. That is not cheating. It's either move the pan, or manipulate (cut or bend) the lip on the timing cover to get it on. Cannot remember how many dozens of times I have dealt with this in friends' and customer's engines. Who's bright idea was it to put Nylon teeth on the cam gear anyway? So what if it's a bit more quiet.
Old 01-15-2013, 12:07 AM   #21
Andy4639
Old member
Andy4639's Avatar
Here are a couple of complete pictures.
