Can I Move This In????
Hello again everyone,
Sorry another question. Is there a way to move the steering column in? Im kinda of a big guy and the steering wheel rubs when I am sitting in the truck. |
Re: Can I Move This In????
Not sure about going in but a smaller wheel and or a tilt column. Would sure help.
Posted via Mobile Device |
C/10 junkie
Kevin of KevsClassics did mine and what a world of difference. Look him up, he's here on the board.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
-Scott- |
#5 | ||
Right on guys, thanks much. I checked it out and it doesn't seem to hard. Thanks Again. |
This is my 71 with a 14 inch Nardi wheel and an early 90's split bench. The seat sits a bit high and makes my 5'10" look like 6'5" to people who see me driving it.
![]() Anyhow this is about the extra room with a 14 inch steering wheel as apposed to a stock wheel. From the bottom of the dash next to the column to the face of the wheel is 14 inches ![]() From the floor in front of the seat to the bottom of the wheel it's 19 inches. You can slide the column down a bit by loosening the clamps that hold it under the dash and out on the firewall and slipping it down a bit. Under the dash is a plate that has to be removed and then you can reach the clamp and loosen it. You can see the clamp in the oval hole in the plate here. ![]() Terrible photo but you can see the clamp on the outside in the middle of this photo. ![]() As it's a column shift automatic you will have to adjust the shift linkage after you slide the column down to compensate. ![]() You will also have to collapse the slip joint in the shaft between the U joint and the rag joint a bit to compensate for sliding the column down and that is going to be the hardest part of the whole deal. I'm 5-10 and 280 and fit in my truck fine with plenty of room but as I said the seat could be a bit lower and I have been thinking about sectioning the seat bases to lower it an inch or so.
This was the first thing my son and I did to our truck.
My son was 8 at the time and with just a little direction and some hand tools, he did all the work himself. WE only went in a little over an inch because the neutral safety switch hits the firewall pad, but that was enough to give us some breathing room. check it out... 1st post http://67-72chevytrucks.com/vboard/s...d.php?t=513605
68-SWB, 327, hooker headers, spintec mufflers, disk brake 3.5/5 drop, buddy buckets, 200-4R, 2200 stall, 3.73 12bolt Eaton Posi, ![]() ![]() All my Google Albums |
it is possible to move the colum down, but you will need to modify your shift linkage
