![]() Join Date: Jul 2012
Not a build thread - more of a 'suggestion' thread...
So a few years ago I picked up this 68 C10. It had a bunch of work professionally done 14 or so years ago, including a chop, a drop, and a shorten. I was enthusiastic about the truck and didn't look at it exceptionally close, but was happy it was low, loud, and kinda fun
![]() ![]() The truck bottoms out on every single bump. It may have something to do with the drop, which features no springs whatsoever - a simple set of coil-overs between the end of the trailing arms and the frame. I'm thinking a 3" notch would help, but I'm also trying to think what else I could/should do to get this thing to ride a bit better. The potential options so far include: - Airbag the rear (simple setup with schrader valves) and new shocks. Not sure exactly where it would mount to, but would need a bit of creativity - Go with a complete bolt-on 4 link replacement. There is already a panhard bar, but the crossmember would take the exhaust, which already gets knocked off a few times each summer. So - anyone have any suggestions/thoughts/alternate options? |
I am a Referee of life.
Re: Not a build thread - more of a 'suggestion' thread...
I would look at factory style lowering springs.Barring that,a new set of coil overs might be the best bet.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
these trucks ride great with just the factory rear spring setup, if I where you depending on how much you want the rear dropped.
I would use a spring/block combo to achieve the drop you are after. 6" drop = 4" springs 2" block (16"+ wheel size) 6" drop = 5" spring , 1" block (15" wheels) and so on for what ever drop you want. Few things to keep in mind, 1.5" max block with 15" wheel. (just piece of mind, if you get into some rear tire trouble, or you go off the side of the uneven road, your U-bolts will not scrape the ground.) "should" put in notch if you go over 5" total rear drop. You can get away with no notch, but bottoming out here and there will happen. As for shock, I would use your current coilover location and replace them with some Monroe or KYB shocks. Just my 2 cents. Scott
68-SWB, 327, hooker headers, spintec mufflers, disk brake 3.5/5 drop, buddy buckets, 200-4R, 2200 stall, 3.73 12bolt Eaton Posi, ![]() ![]() All my Google Albums |
#4 | |
the front or the rear? The rear definitely as the coil overs are too long for the application. You don’t have enough travel in the long body.
leave your stock trailing arms…no need to waste time money and effort on a new suspension when yours is perfectly fine. |
It's the rear - the front is fine as is. My wife hates riding in the truck as the sudden *bang* and launch on bumps tends to make her scream (funny - she likes roller coasters, so this should be ok too... )
Thanks for the input - it's appreciated. So the plan: A set of rear bags and new shocks *should* make a substantial improvement. I'll also add the C-notch to provide additional clearance, and all should be good. For bags there are many height options. Would you aim for a set capable of going to max height, say 10", and run at lower pressure for a standard ride height? |
#6 | |
any of the "normal" rear airbags will work. RE7 or RE8 frmo slam speciaties work great. or "2500" pound firestone bags, or really any of the equivalents. |
it certainly looks like its your coilovers bottoming out you hardly have any travel in the shock. i bet that gets annoying
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
Thanks BK2 - will get started on 'the plan' and should be in good shape when the roads are clear!
Midniteblues - I'm used to it, but when the wife is on the passenger side most every bump is accompanied by a scream ![]() ![]() |
Truck looks like it would be a really fun project.
As for suggestions...ah, my build is kinda nutzoid and not sure how far you want to dive in. Myself, I put a blind folded on and just started runnin'. Will be checking in on your progress. ![]() |
Bomp - this is funny - just spent the past 90 minutes reading your build and watching vids (TIG 101 for McMurphy should be on Comedy Centrals 'metalwork edition'
![]() I've got a bit of a background in metalwork (Navy metalworker on ships 20+ years ago), but I'm pretty rusty now (geddit? ![]() Thanks again for the pointers. The next one may be more nutzoid ![]() |
Gort a call that the Porterbuilt bits are shipping on Monday. We got a few nice days, and decided to get the bed off the truck.
Old member
That is one of the better setup's you can have for these trucks.
It looks like you need a better spring for the coilovers. The picture say's it all the spring is to weak for the truck weight. U need to find a better spring. The bottom collar is almost as far up as it can go and making the spring tighter. You don't have enough travel in the shock to make it ride good because of this It's either wore out are the wrong spring was used in the first place. Go buy a set of new springs for them and I bet your ride will be fine.U need a spring that can carry the trucks weight though. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#13 |
Thanks for the info Andy. The shock has been smacking for awhile now and probably well past it's 'best before' date. The new rear suspension should be here shortly, including shocks and air springs for the rear. It's likely overkill for what I need, but kinda fun. The trick is knowing when to stop
![]() Posted via Mobile Device |
#14 |
![]() Join Date: Aug 2010
How did you pull your bed off with the cherry pick? I need to do this as well and need some advice on how to go about it.
1970 C10 to K20 conversion 1974 GMC Jimmy 1968 50th Anniversary Short Bed 1968 Chevelle 1964 Comet Caliente 1990 W250 Cummins |
#15 | |
I've been toying with the idea of putting a chain hoist in the workshop - that would have been even faster, and will likely be in place when this goes back on. Posted via Mobile Device Last edited by Killick; 02-18-2013 at 02:29 AM. Reason: Fixed a typo |
#16 |
So found a set of 20" wheels for a super good price today. They have Nokian Hakkapelitta winters on them, and fit on the Grand Cherokee, so put em on today for fun. I should have taken a pic of the centres - there are 10 holes in there, so it will fit on multiple 5 lug rotors. This means I need to switch the C10 from 6 to 5 (more stuff onto the list of things to do), but the wheels will look pretty swish.
The colour doesn't show well in the photo, but it's a hematite finish, kinda pearlescent grey. Last edited by Killick; 02-18-2013 at 08:49 PM. Reason: added wheel colour |
