Old 01-06-2013, 09:19 PM   #1
turbosix
turbosix's Avatar
Standing Water
My fleet side bed is hold water. I would think after 40 plus years someone would have drilled drain holes by now. I did a search but couldn’t find anything on the subject. Does anyone have any tips or things to be careful of? It seems pretty straight forward. Thanks for the help.
Tommy
1 Pt. 3:21
'72 C10 LWB 402
turbosix is offline   Reply With Quote
Old 01-06-2013, 09:26 PM   #2
sjarrett71
sjarrett71's Avatar
Re: Standing Water
Every truck I've had had rust holes in the bed!
Seriously though, there should be drain holes in the bed up by the cab. One on each side.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 01-06-2013, 09:26 PM   #3
pritch
pritch's Avatar
Re: Standing Water
I had the same problem and asked the same question. Turns out, there are drain holes in the front of the bed. Yours are just clogged up.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 01-06-2013, 09:29 PM   #4
tommys72
tommys72's Avatar
Re: Standing Water
Yep, they're in there...mine had a few things clogging em up
tommys72 is offline   Reply With Quote
Old 01-06-2013, 09:34 PM   #5
sjarrett71
sjarrett71's Avatar
Re: Standing Water
It's really an ingenious design! The drain holes allow the water to run out right on the cab corners allowing them to rust at an accelerated rate.
-Scott-
Old 01-06-2013, 09:35 PM   #6
tommys72
tommys72's Avatar
Re: Standing Water
Originally Posted by sjarrett71 View Post
It's really an ingenious design! The drain holes allow the water to run out right on the cab corners allowing them to rust at an excelerated rate.
Haha
Old 01-07-2013, 12:37 AM   #7
turbosix
turbosix's Avatar
Re: Standing Water
Thanks for the advice. I will look harder for the holes, I didn't know there were holes already there. I was looking for about a 7/16 inch hole like the later models. I haven't cleaned the PO's junk out of the bed yet, that could be part of the problem.
Tommy
1 Pt. 3:21
'72 C10 LWB 402
Old 01-07-2013, 01:05 AM   #8
PAWS 72
PAWS 72's Avatar
Re: Standing Water
Probably is.
PAWS 72 is offline   Reply With Quote
