Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 01-06-2013, 09:28 PM   #1
novafrog
novafrog's Avatar
air compresser
i got a used air compresser from a guy,when i got it home and hook it up,it had air coming out of the plug where you put oil in,must have air getting in crankcase,can anyone tell me what the trouble is,and how to fix it,thanks
72,2wd short bed cheyenne,350,350trans,air,tilt,tach,posi 373 gears
70 nova 5.3,350 trans
80 z28 350,350,trans,bought new
03 cat.
06 gmc swb ext cab
novafrog is offline   Reply With Quote
Old 01-06-2013, 09:33 PM   #2
hayhauler71
hayhauler71's Avatar
Re: air compresser
i will say the rings are shot
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 01-06-2013, 09:42 PM   #3
_Ogre
_Ogre's Avatar
Re: air compresser
there might be a little air coming out of the vent, especially on a used compressor
it should stop when the compressor is off, if not then the check valve in between the pump and the tank is leaking
if there is excessive air coming out of the vent the rings may be shot
the check valve should be in the line from your compressor and screwed into the tank
shop air compressor timer
Old 01-07-2013, 01:49 AM   #4
Skruffy
Skruffy's Avatar
Re: air compresser
I agree with everything said so far. I think the question is - how much air is coming out?
Someone correct me if I'm wrong, but there will be crankcase pressure from the pistons an crank moving. If the rings are worn it will get worse.
I guess the question is: How does it pump up? How does it work for you? Does it spray oil out?
Skruffy is offline   Reply With Quote
Old 01-07-2013, 11:21 AM   #5
novafrog
novafrog's Avatar
Re: air compresser
they is very little air coming out of vent when compressor is off,thanks
03 cat.
06 gmc swb ext cab
Old 01-07-2013, 11:25 AM   #6
novafrog
novafrog's Avatar
Re: air compresser
very little air is coming out,it takes 7 or 8 min.to pump from 0-125,every now and then it will spray a little oil out,thanks
03 cat.
06 gmc swb ext cab
