Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 01-06-2013, 11:42 PM   #1
mrsmothers
zep parts cleaner queston
So I got a drum of zep solvent based parts cleaner for free. I got it for free because it got water in it. So the question I have is which weighs more zep or water?
mrsmothers is offline   Reply With Quote
Old 01-07-2013, 01:52 AM   #2
Skruffy
Skruffy's Avatar
Re: zep parts cleaner queston
Does the water float on top? I assume it would. Wouldn't that mean it's lighter?
Skruffy is offline   Reply With Quote
Old 01-12-2013, 11:07 AM   #3
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Good score! What you have is primarily a light grade of naphtha and, if you go to buy
it new, it's pretty pricey.
If you are going to try to get the water out of it, get it as cold as you can first.
In fact, I would try freezing a small amount to see if the solvent stays liquid while
the water turns to ice.
The MSDS for Zep’s Parts Washer Solvent is HERE.
Specs gleaned off the net:
Specific Gravity of the solvent is .79 vs. water at 1.0. As for the Specific Weight,
not sure about your exact solvent but gasoline (your solvent is probably just a
tad heavier than gasoline) is 42.5 lb/ft3 vs. water at 62.4 lb/ft3
Note that it is both a combustible liquid and the vapor is explosive, so safe storage
temperatures and handling is a must.
Also, there are some personal protections needed when working around it.
Again, congrats on the great score!
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
