turns off??
My truck 82 c10,
Has new gas tank,fuel sending unit,fuel pump, fuel lines,new sparkplugs and wires, new vaccum lines, new carb, Has an inline 6 250 4.1 Original transmission Cranks up really nice no issues, when its on parked i can step on the gas pedal all the way down and it accelerates without any problem, but when its warmed up, i try to put it on drive, and i pushed on the gas a little and shuts off like if it didnt had any gas, Sometimes it will move but still everytime it like drawns, but after it shutts off it cranks right up with no problems Any ideas? Posted via Mobile Device |
Re: turns off??
Sounds like the accelarator pump is shot. If it dies when you hit the gas it's from a rush of air and not enough fuel. If it chokes stumbles and dies it may be a leak or to much fuel. But it's hard to get to much fuel. It has to be dripping in ther to do that
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Re: turns off??
It strumbles and dies, even if i just press on the gas a little it want to die
Re: turns off??
also make sure your choke isnt shut
Re: turns off??
Post a picture of your carburetor, we can help if we can see what we are trying to guess about. But from what you are describing your accelerator pump is bad.
Can you very slowly push on the go pedal and make the engine rev up? |
Re: turns off??
I will post pics later and it doesnt matter how slowly u push on the gas it dies sometimes acts like its drawning then comes back
