Old 01-07-2013, 11:34 AM   #1
mlevario99
Exclamation Steering Column
I bought this 33" steering column from Ebay, has any one used them before, how do you connect the neutral switch, do you have to add one to the tranny, I am doing a 5.3 swap with the 4L60E tranny.
http://www.ebay.com/itm/Stainless-St...sories&vxp=mtr
mlevario99 is offline   Reply With Quote
Old 01-07-2013, 06:53 PM   #2
64shortbox
64shortbox's Avatar
Re: Steering Column
I'm not sure about a Neutral Safety Switch when using a 4L60E trans but here's how it's done for a Power Glide, Turbo 350 & 400.
A very good write up by Solver:
http://67-72chevytrucks.com/vboard/s...d.php?t=147927
And my lazy man way of doing it using Solver's measurements:
http://67-72chevytrucks.com/vboard/s...12#post5401912
Your column definately doesn't have a provision for a Neutral Safety Switch, but again I'm not sure if a 4L60E trans uses a standard type Neutral Safety Switch or not. Hopefully someone with more knowledge than me will chime in here.
64shortbox is offline   Reply With Quote
