ARGH!! Please HELP! Truck No Start AT ALL NOW!!
Well, I have NO idea why. But for the past couple days, the truck hasn't been starting. Finally, tonight when I went out to try it. I turned the key and it did ABSOLUTELY NOTHING. The lights came on fine and everything, so I know it's got battery power. But when I turned the Key to fire it up, the starter did NOTHING. No buzzing, no clicking, NOTHING. Any ideas? Also, if anyone's got a picture of what wires are supposed to go where on a 75+ Small block starter, it would be GREATLY APPRECIATED! (The Haynes/Chilton manual only has a picture of a small block starter up to 74, it says they changed designs when HEI came out.) Thanks guys! (I KNEW it couldn't be in my ignition!)
I'm back with 2nd truck!
The wires with the large terminal ends go to the large terminal on the solenoid. The smaller wires go to the S small terminal. Plus can't you just swap straight over to the new starter the same way it was?
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
Robert Olson Transport
![]() Join Date: Oct 2002
even if ya put the small wire on the wrong wire it wont hurt it just it wont turn all ya gotta do is switch em
if you are getting power but it wont start, it could be your ignition switch ontop of the column. when mine went out, everything would work (lights, stereo, etc) but wouldnt start, wouldnt click or try or anything. could also be your park neautral starting switch. if its out it will trick your truck into thinking its not in P or N. i had mine go out and i could start it in N but not P.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
How do I fix/test to see if it's the ignition switch on top of the column, or if it's the park/neutral safety switch?? Any pics, diagrams? Thanks!
get a test wire 10 gauge with clips on both ends ...jump the small
post and the big post on the starter...should turn over....its the same thing you switch does only its in the truck!!!!! i have a bump switch hooked up there to set my valves
| Bookmarks |
