Old 01-07-2013, 07:07 PM   #1
KD4UPL
Time for an electronic ignition
My truck is always difficult to start. It cranks fine and has plenty of fuel but seems to lack for a spark. It's still the '71 points distributor. I'm thinking an HEI unit would be much better. I read alot and know a few things about engines but I'm not much of a shade tree mechanic.
What are my options for an inexpensive, reliable ignition system? Does the HEI distributor still need a coil? Will my existing coil work or does that need upgrading too? How hard is installation?
I'm assuming:
Remove old dist.
Slide new one down in the hole.
Connect power and spark plug wires.
Adjust timing? With a light?
Thanks for your help. I may have to call in a favor from my mechanic friend.
1987 S-10 Blazzer Sold, 1986 GMC Jimmy Sold, 2002 Chevy 2500 HD 2wd, 6.0, auto. Sold, 2007 Chevy 3500 SRW 4wd D/A Sold, 2005 Chevy 3500 4wd CC, D/A, dually, 2001 Chevy 3500 4wd EC, 8.1/A dually, 1969 Chevy C10 short bed, 307 V8
KD4UPL is offline   Reply With Quote
Old 01-07-2013, 07:26 PM   #2
First c10
First c10's Avatar
Re: Time for an electronic ignition
Summit racing has a good cheap HEI DIst. with coil for 90 bucks. you will need new wires (or ends) as the hei cap is different then stock cap, and yes time as normal. That is the jeist of it. I have one waiting to be installed when i get my head back form the shop.
Good Luck!!!
YOU CAN DO IT!
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 01-07-2013, 07:39 PM   #3
sanford&daughter
sanford&daughter's Avatar
Ebay has the cheapest one $50 shipped be sure to have it on top dead center pointing at number one cylinder also since your truck still has points in it you will also need to change the resister wire or you won t have 12 volt running to your coil and it will run like crap
sanford&daughter is offline   Reply With Quote
Old 01-07-2013, 08:25 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Don't just put new ends on your old wires.... OEM-type wires aren't made to carry the extra voltage an HEI puts out. You can run the same plugs with HEI (should install new ones though) but they should be gapped at .045 instead of .035. The coil is an integral part of an HEI system, so you don't use your old coil.
I wonder why your truck is hard to start, though. I ran points for many years before switching to HEI (for ease of maintenance) and it always started easily. Maybe you just have a weak coil? Not trying to talk you out of the swap, it's a good upgrade, but the truck shouldn't be hard to start because of points.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 01-07-2013, 08:46 PM   #5
69GWC
I have allways found a HEI will all ways seem to fire off quicker/easyer and give less trouble.
Run a new wire from the fused ING terminal on the fuse box to the HEI, I ran a 12g wire some run a 10g but either way it will need a new wire ran.
69GWC is offline   Reply With Quote
Old 01-07-2013, 09:17 PM   #6
WadmalawJoe
WadmalawJoe's Avatar
I'm in the middle of changing mine to an HEI system. Look for the thread on help with hei install.
Distributors are one of my weakest areas, but with all the help on here I'm doing ok.
Toys/projects
Many toys, not enough time to play!
My youngest son and I picked up a 69 Chevy C-10 on 1/7/22, this is my second 69, it was 10 years ago that I had my other one. So I’m back!!!
WadmalawJoe is offline   Reply With Quote
Old 01-07-2013, 09:54 PM   #7
KD4UPL
Thanks for all the advice. I guess it's hard to start because I only start it once every few weeks and the points either stick or corrode or something. The wiring is a real mess. I have a wire from the firewall hooked to the positive coil terminal which makes sense. I also have a wire from this terminal down to a terminal on the starter solenoid. I have no idea what that is for. I had good voltage on the positive coil terminal but still no fire (I guess) it just smelled flooded and never tried to fire as long as I cranked it.
I had the carburetor rebuilt so I know that's not the problem. I think a new dist., new wires, and new plugs are in order. I know that none of it has been changed in at least 20 years.
Old 01-07-2013, 09:58 PM   #8
KD4UPL
Old 01-07-2013, 10:11 PM   #9
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Since you only start it occassionally,the hard start problem is probably due to the carb draining back or evaporating fuel.You have to crank it to get fue back in the float bowls of the car.Mine does ths with a rebilt carb if I let it set a month or so.Still the HEI will help when it does get fuel.Look in the FAQ's Truck section for a post by member "shifty" on HEI in a 6 to help.He wrote it up for a 6 cyl but the same applies.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
