Old 01-07-2013, 07:48 PM   #1
Randy D
Could someone please tell me if these wheels will fit?
This is my first post so let me apologize if this has been discussed before. I recently bought a 1970 CST-10. I want to put 15x10 Outlaw 1 rims on the back with 295/50/15 tires and 15x8 Outlaw 1 rims on the front with 245/60/15 tires. The truck is stock height so I think it will be OK but I want to be sure before I order the rims and tires. Any advice would be appreciated.
Randy D is offline   Reply With Quote
Old 01-07-2013, 07:50 PM   #2
BarryB
BarryB's Avatar
Re: Could someone please tell me if these wheels will fit?
They should aslong as you have the right backspacing.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 01-07-2013, 08:26 PM   #3
chiefcfd
chiefcfd's Avatar
Those look like 8 lug wheels on there now. That will make 15 inch wheels hard to come by. Are you planning on changing the hubs and axles.
chiefcfd is offline   Reply With Quote
Old 01-07-2013, 08:34 PM   #4
69GWC
Maybe they are 6 lugs, hard to see.
69GWC is offline   Reply With Quote
Old 01-07-2013, 08:48 PM   #5
Randy D
The truck has 6 lugs. The 15x10 Outlaw 1 rims have a 4 inch back spacing and the 15x8 Outlaw 1 rims have a 3.75 inch back spacing.
Old 01-07-2013, 08:53 PM   #6
69GWC
Not sure about 2wds but on my 4wd that bs would be about perfect, truck will look good with those wheels and tires on it.
Are you going to drop it any at all.? Couple inches would look real nice with that tire size.
Old 01-07-2013, 09:47 PM   #7
Randy D
Thanks for the replies guys. If I do lower the truck it would be just slightly. I like when the back is higher than the front. The new tires are going to be two inches shorter than the ones on it now. It's hard to find wide 15 inch tires that are 28 or 29 inches tall other than Mickey Thompson Sportsman S/R tires but they're expensive.
Old 01-07-2013, 09:52 PM   #8
69GWC
ProTrack sells some like the MTs that are cheaper, a N50 15 would look real mean on the back.
I used to run them on the back of my 75 that was slamed with Outlaw ll.
