Old 01-07-2013, 09:33 PM   #1
Racinaround
Racinaround's Avatar
I need a few things
I need a steering column firewall bracket and clamp
and a the peice of metal that goes between the upper column bracket and the park brake handle!
68"
1950 Chevy 1500
1961 C-10
1969 C-10
1971 Chevelle
2008 Dodge HD3500 Tow Rig
Racinaround is offline   Reply With Quote
Old 01-08-2013, 04:52 PM   #2
Racinaround
Re: I need a few things
I had a email saying somebody relpyed to my post but there is nothing there??????
1950 Chevy 1500
1961 C-10
1969 C-10
1971 Chevelle
Old 01-08-2013, 05:45 PM   #3
blkcorvair
blkcorvair's Avatar
I think I have the firewall bracket and clamp. Not sure what piece your reffering too by the park brake handle. Maybe you can dig up a refernce pic on the forums and post it?
blkcorvair is offline   Reply With Quote
Old 01-08-2013, 05:56 PM   #4
DaHos
DaHos's Avatar
That was me.........I have the firewall bracket and clamp but was thinking you needed the column trim (metel plate) which I have. After thinking about it I think you are looking for the 4 bolt hole metal bracket that mounts to the pedal box and then the ebrake mounts to it......correct?....If so I dont have an extra, FWIW I do have one for a 69-72...
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 01-08-2013, 06:55 PM   #5
Racinaround
Well i guess i need both peices for the column inside and the firewall pieces!!
I only have the brake handle! and the colmn is only held in with the two bolt strap with the indexing bump on it!
1950 Chevy 1500
1961 C-10
1969 C-10
1971 Chevelle
Old 01-08-2013, 06:57 PM   #6
DaHos
DaHos's Avatar
Nope the one on the right is 69-72, 67-68 on left. Here is a pic of the column trim.
1967 C10 SWB
Old 01-08-2013, 07:25 PM   #7
Racinaround
I'm feeling dumber by the minute??
I'm putting a 68 cab on a 69 truck and using the 69 parts! most are missing but !
I never knew there was so much different!
Im switching to hand ebrake so i need the one on the left
1950 Chevy 1500
1961 C-10
1969 C-10
1971 Chevelle
Old 01-08-2013, 09:02 PM   #8
toyplumbertrucks
toyplumbertrucks's Avatar
I put 72 parts on a 68 cab. The E-Brake on the 68 mounted under the column. The E-brake on the 69 mounts on the driver side under the dash near the cowl. You will have to do alot of work to switch that around, I just did not but a E-Brake System on mine. Also the fuse panel mounts horizontial instead of vertical, there is not anywhere to mount the door courtesy light switches, the door rubber bumpers mount in different spots and the gas pedal may be different. Good Luck! I am starting to get bad memories.
toyplumbertrucks is offline   Reply With Quote
Old 01-08-2013, 09:48 PM   #9
72Bob
72Bob's Avatar
There was a 69 C10 at the Arlington, WA Pick and Pull last week.
1971 GMC Sierra 3/4 Ton 4x4
1972 Chevrolet SWB 4x4
RIP LeRoy
72Bob is offline   Reply With Quote
Old 01-10-2013, 08:52 PM   #10
Racinaround
Thanks Bob!
Im really busy running my shop and need something shipped to me!
Im better prepaired with help from DaHos
#1 I need just the clamp for a 68 steering column thats below the booster
#2 I need the bracket in the pic below for a 68
I dont care if they come from two differant people! just in need!
1950 Chevy 1500
1961 C-10
1969 C-10
1971 Chevelle
