01-07-2013, 09:43 PM | #1 |
Tot Roddin'
Let's see your - Metal Tube Radiator Hose
Curious who has built their own radiator hose out of metal tubing and what you used to make it.
What type of tube did you use? What type of end clamps did you use? Hose ends? Exhaust tubing?
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
01-07-2013, 10:00 PM | #2 |
Re: Let's see your - Metal Tube Radiator Hose
I am new to this and apologize for asking a question instead of giving an answer but....
What's the benefit/purpose to metal radiator hoses? Aesthetic? I'm just trying to wrap my head around it, I've never seen something like that.
It's not that I am apathetic, I just don't care. If your life is a joke, it appears death will be your punchline. |
01-07-2013, 10:03 PM | #3 |
I am a Referee of life.
I don't have one but IIRC some if not all 4X4's had a metal upper rad hose.They were used on them to keep a flopping hose out of the fan I guess.Not many left.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
01-07-2013, 10:23 PM | #4 | ||
Tot Roddin'
I know safety comes first. Either placing a weld bead line around the ends to create a radius around the tubing, or whatever, make sure the hose doesn't have a blow out when under pressure.
01-07-2013, 10:28 PM | #5 |
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help. Last edited by 72BlckButy; 01-07-2013 at 10:51 PM. |
01-07-2013, 10:34 PM | #6 |
C/10 junkie
I was thinking of making one for my truck at work. Bend some correct size exhaust pipe and flare the ends. The pipe is aluminized steel so it won't rust very easy plus you can paint it or powder coat it.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
01-07-2013, 10:36 PM | #7 |
'85 Stepside
it's a aluminum spreader bar from a cargo box.(tractor trailer) As long as it is 1 1/2'' is the main thing ,you can use exhaust tubing and weld a bead around each end to prevent slippage.
01-07-2013, 10:43 PM | #8 |
Tot Roddin'
I never get tired of looking under that hood hot trux...
That is exactly what I'm looking for.
01-07-2013, 10:47 PM | #9 |
Old member
Here is mine. Aluminum Conduit I cut. The only problem is it's heavy and it keeps cracking the solder joint on the upper radiator neck. I have it tore a part and plan to have it rebrassed and see what I can come up with to releive the stress on it. I haven't had any problem with it sliding out of the rubber hose ends. I scuffed them up real good before inserting them.
01-07-2013, 10:49 PM | #10 |
Tot Roddin'
What rubber tubing are you guys using? Cutting up another hose? Using straight pieces and bending the tube?
01-07-2013, 10:49 PM | #11 | |
Old member
01-07-2013, 10:52 PM | #12 |
Old member
I used the old hose for the ends when I replaced it with the pipe. I bent my pipe but the hose ends can be used for that also.
01-07-2013, 10:52 PM | #13 |
The Few, The Proud
Here you go Nate. This is on a local truck. He used exhaust pipe. One short straight section and one 90.
Shannon |
01-07-2013, 10:53 PM | #14 |
Tot Roddin'
Yep... that's in his garage.
01-07-2013, 10:54 PM | #15 |
Tot Roddin'
That is nice and clean; thanks for posting that buddy!
01-08-2013, 08:34 AM | #16 |
Thanks for bringing this subject up, Nate. I need to do something like this on mine. Since the LS1 swap, the only negative I get is about my upper hose.
01-08-2013, 08:56 AM | #17 | |
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
01-08-2013, 09:37 AM | #18 |
Bought these mandrel bent pieces from griffiths radiator on line. They are 45s and 1 3/4" , for my lower pipe, then just connected with strait hose. Pipes about 20 bucks apiece
20130108_082930 by jarosaj, on Flickr
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
01-08-2013, 10:39 AM | #19 |
Anyone running stainless tubing?
1970 GMC 1500 stepside 1972 GMC Jimmy Custom 2004 Chevy Colorado 1989 Swb Silverado 1972 Aj's Stormer |
01-08-2013, 10:46 AM | #20 |
FWIW, Matco has a bead roller for tubing. I saw it on Horsepower Tv...Haven't found it again since then.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
01-08-2013, 11:10 AM | #21 |
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
Heres one from Hazel...
Down......with the sickness!! |
01-08-2013, 11:25 AM | #22 |
67cheby
tuned in i want to do the same thing to Cloud 9
01-08-2013, 11:46 AM | #23 |
another sweet mod for cleaning things up a bit. Thanks for posting about this... I will do this to mine when I get to that stage.
01-08-2013, 11:52 AM | #24 |
This IMHO much better than the aftermarket over priced custom stuff out there. A powder coated custom for your application makes sense.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
01-08-2013, 02:33 PM | #25 | |
Tot Roddin'
That is quite a radiator hose you have under the hood. I never would have guess that this was stock from the picture. I knew "the man" had done this on his trucks in the past just couldn't locate a picture on my computer last night. Thanks for posting crawdad!
