Old 01-08-2013, 12:25 PM   #1
terrylgreenjr
oil pressure gauge
For starters I swaped a 91 Suburban cluster into my 77 K5. I repined everthing to match the new cluster and i bought the oil pressure sensor to match the cluster. everything else works correctly in th ecluster except the oil gauge. When the truck is off it sit on the 60 psi mark and when I start it it pegs out horizonal past 60psi Any sugestions?
terrylgreenjr is offline   Reply With Quote
Old 01-10-2013, 02:13 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: oil pressure gauge
Is this a hydraulic gauge or does it use an electronic sender? If its a standard gauge....you probably have a restriction in the tubing creating a false pressure. Got any kinks?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-10-2013, 03:40 PM   #3
terrylgreenjr
It's a electronic gauge
Old 01-10-2013, 07:31 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
unplug the connector and see if it goes/stays wide open, then touch the lead wire and see if it hops around. If not, you have have either NOT grounded the sensor (common in repinning when the ground was through the harness), or the ground was shorted OR, you grounded the wrong wire.
IIRC NO ground is FULL pressure, shorted is none.
Old 01-23-2013, 10:34 AM   #5
terrylgreenjr
Ok last night I figured out it was in the wrong pin on the cluster. When I repinned it and started the truck it went all the way left. I guess I was asleep when I wired this up. Which pin on the 3 pin oil pressure sensor is the feed for the gauge. If I wired the cluster wrong I probably used the wrong wire on the sensor too. I've gotta stop working on this truck after working a 12hr shift
Old 01-23-2013, 02:43 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I'm not sure I'm following this right....so what year vehicle is the actual sensor from, the 91?
Take a look at this other thread from here and see if it helps, I don't know the 80-90's wiring much by heart.
http://67-72chevytrucks.com/vboard/s....php?p=4893857
It shows power from the A pin, apparently no matter which plug (3 or 4 pin)....A being the top pin, by the "clip" on the connector.
Old 01-23-2013, 05:46 PM   #7
terrylgreenjr
I switched the instrument cluster so I could have electronic speedo. Then I bought the oil pressure and coolant sensor to mactch the cluster. I resized the coolant sensor to thread in the passenger side head for the coolant temp, and now working on getting the oil presssure to read
