Old 01-08-2013, 03:10 PM   #1
wlf89
69 c/10 lwb fleetside
wlf89's Avatar
fuel pump to sending unit hose 87 chevy truck
the 2 inch or so lenght of hose that connects the pump to sending unit,does it have to be special hose or just standard fuel hose?
finally got tank ripped off dont know if ill ever get it back on couldnt get to none of the clamps for the bed so i cut them off dont know how hard it will be to get the new hoses hooked up maybe not to bad.
69 lwb fleetside
67 swb fleetside
(2) 72 lwb fleetside
50 swb no bed
65 impala ss
65 1 ton flatbed
wlf89 is offline   Reply With Quote
Old 01-08-2013, 03:22 PM   #2
bohmankid
bohmankid's Avatar
Re: fuel pump to sending unit hose 87 chevy truck
Your fuel pump should only be pushing 15 psi. So any fuel hose with clamps should work fine. Go to your auto parts store and grab some fuel hose. Someone there should know what to get you. Tell them it's part of your fuel system. It is not high pressure.
bohmankid is offline   Reply With Quote
Old 01-08-2013, 03:24 PM   #3
hyatt
I will have to dissagree regular hose will not hold up Take it from someone that learned the hard way Get the hose designed to be in gas all the time
1946 car hauler
1948 surburban
1937 chevy sedan
1940 olds sedan (project)
1967 ss396 chevelle
1999 dually crewcab(24000 miles)
hyatt is offline   Reply With Quote
Old 01-08-2013, 04:34 PM   #4
school boy
school boy's Avatar
my new pump came with the hose, but like mentioned above, get the right ones. most auto parts stores can help
school boy is offline   Reply With Quote
Old 01-08-2013, 05:13 PM   #5
rs72z
rs72z's Avatar
Get good hose not cheap stuff. The ethonal in the fuel will swell the cheap hose and it will burst.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 01-08-2013, 05:15 PM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
87, sounds fuel injected
use proper hose and clamps required
bet you wouldn't want to do that tank twice
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 01-08-2013, 05:30 PM   #7
Pyrotechnic
Pyrotechnic's Avatar
http://www.oreillyauto.com/site/c/de...0887&ppt=C0222
Go with Gates Barricade line. It's designed specifically for today's alcohol blend fuels and good to 50 PSI. A TBI pump only puts out around 12 PSI. This stuff will last a long time.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 01-08-2013, 07:41 PM   #8
pontgta
pontgta's Avatar
For the outside it would be "OK" to use regular fuel line hose ... for the inside tank... get fuel injection hose. That is thicker and will withstand being submerged in fuel all the time
oh also get some good clamps....When i did mine i made the hoses reach down to the floor so i can hook them up and not have to hold the tank up...
pontgta is offline   Reply With Quote
