Old 01-08-2013, 05:09 PM   #1
David623
5.3 Vortex motor question
I just picked up my motor, and I have a few questions of concern? 1. I was told I was getting a 2003 5.3 Vortex motor, transmission, and transfer case, what I got when I ran the vin# it came out to be out of a 1999 Silvarado. The motor has been completely rebuilt. Should I have any concern about the motor? 2. It also went $1500 over original estimate. Is there a difference between a 1999 vrs 2003 motor?
David623 is offline   Reply With Quote
Old 01-08-2013, 05:59 PM   #2
Firebirdjones
Re: 5.3 Vortex motor question
There were some changes made like camshaft profiles and compression ratios depending on the model. If it's been rebuilt it's hard to say what you have now unless machine shop provided you with specifics on the build.
I'm not as familiar with the 5.3's on this fact but I can tell you that the 6.0's used cast iron heads up through about 2000 and didn't get aluminum heads until 2001.
Firebirdjones is offline   Reply With Quote
Old 01-09-2013, 01:17 AM   #3
blazer1972
blazer1972's Avatar
if u still have the a 350 tranny and transfer case i will keep it in the truck, both will work great, but fixing a 350 is cheaper in the future. if engine is rebuild it will work as new,
blazer1972 is offline   Reply With Quote
Old 01-09-2013, 02:25 PM   #4
OldCreek
OldCreek's Avatar
You should post over in the LSx section in the engine area.
Probably, you're o.k. as long as you trust your engine builder...
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 01-10-2013, 08:45 PM   #5
truckeez
the 2002 earlier are worst for the piston slap problems so the guy didn't want to tell the truth--bad for gettin rid of it.
truckeez is offline   Reply With Quote
