Upgrades to 72 6 Cyl
The carb on my 67 (has 72) most likely needs rebuilt. What is a good carb to replace this with that is basically bolt on and go.
HEI distributor... where do you get them for a 6 and is there anything special I should know before replacing? Any other mods that will make it run better and keep it somewhat stock looking? |
I am a Referee of life.
Re: Upgrades to 72 6 Cyl
Use the carb you have.They're easy to rebuild(I can do it) and the LAPS should be able to get you a kit.I used a 250 HEI from about a 78.I had to change wiring cap and I replaced plugs since they were due and needed regapping,The kit had good instructions and only took me abot 2 hours from start to finish but I didn't soak parts I just cleaned it since it wasn't a show truck.You can put a Pertronix ignition in and keep the stock cap if you really want to retain stock look.Be aware that te HEI will not clear the factory A/C compressor and bracket if you use the coil in cap HEI.There is a version with a divorced coil if you can find one.
BTW get any #'s and such you can off of the carb to help identify which kit you need.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#3 | |
Active Member
![]() Join Date: Jul 2007
I responded to your other post on the engines and drive section in reference to your question about the carb.
Re. the HEI. I got mine from a later truck (as mentioned above) from a local salvage yard for about $20-$30 and rebuilt it. You can also find them on ebay. Just do a search on inline six HEI distributors. Here's a link. http://motors.shop.ebay.com/eBay-Mot...0.l1313&_rdc=1
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
![]() Join Date: Aug 2008
#6 | |
Active Member
Funny story about acronyms. I was in a hopped up Camaro years ago and wasnt doing the speed limit etc. A guy on a Harley pulls up to me and says I needed to slow down. The bike was all decked out in LAPD decals etc. I think to myself I am in Michigan(at the time) must be a replica bike. So I blew him off. Well I was in Lake Angelus lol hefty ticket on that one.
Langdon Sovebolt seems to be a good resource. I bought my separated cap and coil HEI from him, but Tom is a wealth of information, not just a parts slinger.
1972 Pale Yella 2WD Blazer ..... 350HO/700R4.... '68 Clipped 1970 Original Paint SWB Farm Truck ..... 5.3/4L80.... 2x HRPT Participant |
Try this site for a brand new Distributor. I bought one and works great and excellent people to work with!
http://whiteperformance.com/ |
